I was given an Empire propane gas heater (50,000 BTU). Some things are missing, or just out of place. On the back of this unit where the the vent is,there should be a shroud with some kind of sensor in it. Is that shroud and sensor available? :confused: The thermocouple is hanging out of it, does this go in the vicinity of the pilot light?:confused: Thanks for the help with the magnetron question. Had to trash the nuke!:D
