Why Does The Water Ionlet Line Into Ice Tray Keep Freezing Up?
Hello, This normal happens due to either low water pressure (bad filter) Or a faulty water valve. If you have slow or weak pressure water will freeze in the line, if the pressure is fine I would suspect a faulty water valve. Appliance Repair Technician:
