:( my refrigerator is too hot on the frame, side by side.i assume that i need to replace the microcomputer pc board part#AP2993442. I DON'T KNOW HOW?.
I cannot kind info on a KSC25INSS00, the following is for a KSCS25INSS00. Here is the parts breakdown. Replacement parts for WHIRLPOOL KSCS25INSS00 REFRIGERATOR | AppliancePartsPros.comIf the only symptoms is a hot frame and probably the unit is running too much then check that the condenser/compressor fan is running, that the condenser coils are clean and that the vent louvers (front and back) are clean. See Section 11 in the parts. |
THIS FORUM IS DEAD!!!!!!! |
