| » Install push panel |
Model Number: mzd2665hew Brand: Maytag Age: 5 - 10 years
Have new push panel (facade). Do I pull off the old one and stick on the new? This sounds too simple. Or do I remove the two screws under the drain tray and remove the whole panel and ??
Yep. The 2 screws behind the drip tray & it will slide slide down about 1/8 inch & pull away. I just replaced the facade on my maytag. I had to install a new indicator label (insert) since the new facade did not come with it.
Quote:
Can either of you help? Thanks! |
| Display Modes | |
| Detergent Cup Arm and Spring on inner Door Panel - How to install? | AppPartsUser10 | Dishwasher Repair | 1 | 09-23-2010 07:49 PM |
| need to take front panel off to install timer knob | jossey1 | Washer Repair | 1 | 06-18-2010 07:02 AM |
| push button panel problem | hudson | Dishwasher Repair | 1 | 03-07-2010 07:34 PM |
| Re-Set Panel Lights after Install | jayman7 | Oven Repair (including Ranges and Cooktops) | 0 | 04-14-2008 10:34 PM |
| Some Cotrol Panel push buttons do not work | MartinG | Dishwasher Repair | 3 | 01-07-2008 12:19 PM |
