Hi everyone,,, I am wanting to place my refrigerator as far back against the wall as possible. The waterline connection may limit just how far back I can place it unless I can find some sort of special hose with a 90 degree connector on one end OR a 90 degree adapter coming off the water valve. I'm thinking that a 90 degree connection off the water valve (spigot) will allow the hose to tuck more closely between the wall & refrigerator allowing me to place it closer to the wall. Does anyone know of such a hose or 90 degree adapter that will work or other suggestions ?? Your feedback is appreciated
Forgot to mention that the connection hose uses a 1/4 inch compression type ends
