Register | FAQ's | New Posts | Today's Posts | Extras |
» GE Defrost problem |
![]() Model Number: GSS22SGMCBS Brand: GE Age: 5 - 10 years
![]() I have a GE refrigerator GSS22SGMCBS the defrost cycle was not working (evap coils icing up refrigerator getting warm etc...). When I first found the problem I noticed the defrost heater was black and did not give an ohm reading so I replaced the heater and the thermostat. A couple weeks later the problem resurfaced – apparently when the defrost cycle kicked on it burned out the element in the glass heater. The coil was broken in the middle. Thinking I had a short in the thermistor I replaced the thermistor attached to the coil and put in a new heater. I jumped the defrost cycle (J9 and J11) and the element turned on and glowed for 1 minute then it burned out. What would cause the heater to keep blowing? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Could find very little info on this site but did see that the defrost element is now a dual element. I believe it comes in a kit and you have to splice it in. They run two elements so it supposedly last longer. You may want to give the parts side of this site a call.
The heater should be able to take 120 volts for a lot longer than what you described so I am at a loss as to what would cause it to blow so quickly. There was nothing touching the glass so perhaps a fault, direct from the factory. The glass type heaters are crap and always will be so instead of replacing it with a decent ceramic type GE in their wisdom put in two of them. Oh well I guess that it is better than nothing.
__________________
![]() The heater element I used is:
Model number: CST20KABEAD Part description in this model: HEATER & BRACKET ASM Part location: #230 This part did contain the duel heaters. However, I figured one heater has worked for 5 or so years so I removed one heater from the set and placed it in the single heater bracket. It seems like 2 heaters may be more efficient but whether I used one or two it should still last longer then a minute? I'm wondering if the motherboard could cause a short? |
![]() Thanks for your help - I don't disagree with you at all. I went on the assumption that each of the heaters supplied with the dual system would function individually and be equivalent to the single heater that came with the frig? You believe the heaters supplied with the dual system are different from the original.
![]() They did not put 2 in to make it more efficient.
They put 2 in and wired them in series so you get the required heat output but each element does not get as hot. Each new element has approximately half the resistance as the original so when you plugged in only one you got twice the rated current and poof.
__________________
![]() Quote:
This is the part I ordered, and I did not get instructions. I am trying to replace a single defrost heater with this. Do I plug the blue and pink plugs into one end of this dual unit, or do I have to splice in something as was mentioned earlier in this thread? I am not a repair person. I watched the repairman replace the heater before with another single unit. I was trying to do it myself because I cannot afford a repairman to come out. |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
defrost problem | geno630 | Refrigerator & Freezer Repair | 0 | 02-14-2010 11:11 AM |
Defrost Problem | Jeff R | Refrigerator & Freezer Repair | 2 | 01-11-2010 07:41 PM |
Defrost Problem | wickedwickham | Refrigerator & Freezer Repair | 4 | 12-13-2008 02:41 PM |
defrost problem | Judy2857 | Refrigerator & Freezer Repair | 1 | 12-11-2008 11:10 AM |
GE Defrost problem (Defrost heater fuses ?) | rkpatt | Refrigerator & Freezer Repair | 0 | 08-03-2008 05:24 AM |
