| » maytag side by side does not get cold |
Model Number: msb2154drw Brand: Maytag Age: 1 - 5 years
When I plug the refrigerator in the compressore get hot and it sounds like a relay is clicking but the fridge never get cold.
Replacement parts for MAYTAG MSB2154DRW REF - SXS | AppliancePartsPros.com If the compressor relay is clicking on/off then the below does not apply. When you say that the compressor gets hot, I am assuming that you can hear it come on and that you can feel it vibrating. Also that it is running continuously. Are both the condenser/compressor and the evaporator fans running? If yes then unplug the unit and remove the evaporator cover in the freezer so you can see the coils. If they are heavily iced/frosted over then you have a defrost problem. I doubt this since you are getting no cooling at all. If they have no frost or just frost in one area, you have a sealed system problem. In this case the repair will be expensive as you will need a pro. Also there is no guarantee that it can be fixed long term. Usually it makes more sense to invest those dollars in a new unit.
__________________
Hello,
Sorry for bumping an old thread, but I am having this same problem although I am not sure which part it might be. I have looked at the link but I cant figure out which part needs replacing for this. The unit sounds fine, it is just blowing warm air and not getting cold. Thanks for the help! -Rob Quote:
| Display Modes | |
| GE GSS25JFPAWW Side by Side Refrigerator Side Not Getting Cold | TSKW914 | Refrigerator & Freezer Repair | 2 | 01-11-2011 07:09 PM |
| Kenmore side-by-side too cold in fresh food side. | scorp508 | Refrigerator & Freezer Repair | 9 | 01-09-2011 12:48 PM |
| Maytag side-by-side too cold | malescat | Refrigerator & Freezer Repair | 2 | 11-30-2010 05:42 PM |
| GE side by side refrig tfh22prsm ww leaking from bottom, no longer cold either side | thomashaskins | Refrigerator & Freezer Repair | 3 | 09-13-2009 07:01 PM |
| Maytag side by side Freezer cold Refrig warm | timbruns | Refrigerator & Freezer Repair | 2 | 06-10-2008 05:11 PM |
