| » public1 |
Model Number: tpx24pbbjaa Brand: GE Age: 5 - 10 years
now one can Id. the tempiture control on the left hand side of the refer box seting under the freezer control marked rdi8-2004 rev11 Roberty Shaw control
Here is the parts breakdown
Replacement parts for General Electric TPX24PBBJAA Refrigerator | AppliancePartsPros.com Not quite sure what you are looking for but I only see 2 controls Freezer thermostat Item 424 in Section 5. Fresh food damper Item 426 in Section 5. Hope I guessed correctly!!
__________________
Quote:
You did not say it but from your second post I am assuming that the fresh food section is too cold.
Check to make sure the spring in the damper is still there. Click on the picture of the parts and you should get an expanded view of it. If OK Then I would start by checking the freezer temperature. It should be 0 to 5 degrees F. If OK them adjust the fresh food thermostat/damper control using lowest and highest settings to see if the damper door will open/close. Give it about 15 minutes to do this at each end of the range. If it does not close then odds are the damper needs replacing.
__________________
| Display Modes | |
