Recently had evap fan and defrost board replaced about a month ago. Then 30 days later evaporator fan blade stopped because of because of major build up. Used a hair dryer to defrost the ice build up, but am sure this is going to happen again. Any ideas would be appreciated as to what to check for next to prevent this from happening again.
Originally Posted by: RoboJoe Industries Thanks, I will check on that.
