Hi, My side-by-side Whirlpool fridge had a burnt start relay. I got a replacement part but when I pulled the white cable from the bad start relay, I forgot which terminal it was plugged to. There are terminals 1, 2, 3, 4. Terminals 1 and 2 are on the right side and 3 and 4 are on the left side. The original start relay had terminal 1 terminated so that leaves the other 3 terminals as the possibilities. The red cable is plugged into the white part at the bottom of the start relay and stayed intact. There are no other cable plug into the start relay. Any suggestion would greatly appreciated. Thanks. jvrepairman attached the following image(s):
