| » Refridgerator not cold- repair man thinks compressor |
We often use a "3-N-One" start relay/overload device (also called a "hard Start kit") as a diagnostic tool to test compressors. If your repairman was honest with his report of the compressor's not starting, it probably is truly bad.
There are companies who will replace compressors; but the general concensus among modern refrigerator technicians is that you can spend more money on a repair, than on a replacement of the refrigerator. If you trust your repairman, go along with his recommendation. |
Quote:
Their company does not do compressor work for some reason, but said I could expect to pay $400-600 for that kind of work. I looked up the part and it runs $250 if I ordered it myself Last edited by Robak : 02-01-2011 at 03:53 PM. |
The compressor is part of a "sealed system". These sealed systems are really not intended for the kind of service that opens, or breaks the seal.
Replacing the compressor involves opening the system; collecting the refrigerant (The EPA mandates only licensed technicians do this according to strict federal guidelines); replacing the appropriate components; vacuum-testing the system to make sure there are no leaks, and to remove any air and moisture from the system; and recharging the system with new refrigerant. It can take some technicians more than half a day to get this right, and the procedure is fraught with possible call-back producing factors. This is the biggest reason most of us don't perform this service any more. Another reason is the high cost of equipment necessary for compliance to the law. $600.00 is a very reasonable cost for this kind of service. |
Quote:
Anyway, the refrigerator might be working. It had been unplugged all night and I plugged it back in 5 hours ago. The temp is down to 44 degrees. I'll report back in the morning on the temp then. I am just concerned how hot the compressor was. I don't really have a way of measuring it, other than seeing if it would melt a piece of solder. |
| Display Modes | |
| ge profile refridgerator too cold | rjp | Refrigerator & Freezer Repair | 4 | 10-28-2010 10:11 AM |
| refridgerator not getting cold | searchr70 | Refrigerator & Freezer Repair | 0 | 08-25-2010 04:37 AM |
| refridgerator not cooling but compressor runs | bpetska | Refrigerator & Freezer Repair | 3 | 06-16-2009 06:15 PM |
| Feezer and refridgerator not getting cold enough | figgman | Refrigerator & Freezer Repair | 0 | 04-03-2008 11:40 PM |
| Refridgerator suddenly not cold | tjtroy | Refrigerator & Freezer Repair | 5 | 11-06-2007 04:55 AM |
