HI this morning i had a burnt rubber smell from refridg i have been getting a whirling sound from the cond. fan motor and now im hearing a ckicking sound by the cond. the cond.fan is spinning does anyone have any help?
Originally Posted by: acaliendo HI this morning i had a burnt rubber smell from refridg i have been getting a whirling sound from the cond. fan motor and now im hearing a ckicking sound by the cond. the cond.fan is spinning does anyone have any help? There's nothing rubber in the compressor compartment area, other than the compressor grommets, Is everything working properly, other than the clicking noise ? Could you have had a low voltage situation causing certain components and electrical circuits to click ? Did you check and clean the condenser assembly and check for debris ? At this point I'm thinking, Compressor relay/overload making noise, due to voltage or weak contacts, Electronic control board contacts clicking, due to voltage or weak contacts. But you should have other complaints, of temperatures in the refrigerator. :) :) :)
