Discuss
GE Refrigeratior
 in
Refrigerator & Freezer Repair
I have a GE Profile Performance side-by-side fridge (model TPX24SPBA), and have a RO installed for fridge and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE Refrigeratior
  #1 (permalink)
Old 12-08-2008, 10:22 AM
markgamache markgamache is offline
Junior Member
markgamache is on a distinguished road
Default GE Refrigeratior
Model Number: TPX24SPBA   Brand: GE   Age: More than 10 years
I have a GE Profile Performance side-by-side fridge (model TPX24SPBA), and have a RO installed for fridge and kitchen sink. I have what I am pretty sure is the right plug to bypass the filter. Part number WR02X10173).
Removing the filter is a snap, done it many times, just a 1/4 turn and it is off. Like an oil filter on your car, but only 1/4 turn and its off. Problem is that what you then see is not going to accept the plug that I got.
I've looked for an online image of the plug -- no luck. Other than a piece of plastic on the one end to hold on to the thing, it is shaped like TV cable ... it is a hollow plastic tube slightly bigger than 1" diameter, tube wall thickness maybe 1/8", and coming out from the center of the inside of the tube is a plastic pin, about 1/8" diameter, and the the length of the pin extends slightly past the end of the tube, by about 3/8".
What I see in the bottom-center of the assembly where the filter was, is a cylindrical piece of plastic ("nipple") about 3/4" long with a small hole in the end. This nipple is designed to fit in to the opening of the filter. The plastic pin of the plug will not fit in the hole in the end of the nipple, and even if it would, that wouldn't make sense to me, because you'd be trying to get two "male" pieces to fit in to each other, and social commentary aside, that doesn't work very well.
This is why I think that some of the assembly that the filter goes on to has to be removed for the plug to be used. It appears that the assembly has to be turned to the left to remove it, but the assembly will not turn. It may be frozen tight. Is there a special way to remove the assembly? I don't want to damage it.
I have seen this thread started before, but no answer was provided.
Related Models
General Electric TPX24SPBABS Refrigerator
General Electric TPX24SPZBBS Refrigerator
General Electric TPX24SPZCBS Refrigerator
General Electric TPX24SRYABS Refrigerator
General Electric TPX24SRYEBS Refrigerator
General Electric TPX24SRYFBS Refrigerator
Amana TQ18NB Ref - Top Mount
Amana TQ18QB2L Ref - Top Mount
Amana TQ18QB2W Ref - Top Mount
Amana TQ18QBG Ref - Top Mount
Amana TQ18QBL Ref - Top Mount
Amana TQ18QBW Ref - Top Mount
Amana TQ18R2G Ref - Top Mount
Amana TQ18R2L Ref - Top Mount
Amana TQ18R2W Ref - Top Mount
Amana TQ18R3G Ref - Top Mount
Amana TQ18R3L Ref - Top Mount
Amana TQ18R3W Ref - Top Mount
Amana TQ18RBG Ref - Top Mount
Amana TQ18RBL Ref - Top Mount
Amana TQ18RBW Ref - Top Mount
Amana TQ20NB Ref - Top Mount
Amana TQ20QBG Ref - Top Mount
Amana TQ20QBL Ref - Top Mount
Amana TQ20QBW Ref - Top Mount
Amana TQ22NB Ref - Top Mount
Amana TQ22QBG Ref - Top Mount
Amana TQ22QBL Ref - Top Mount
Amana TQ22QBW Ref - Top Mount
Amana TR-17D Misc / Accessory
Amana TR-17D-1 Misc / Accessory
Amana TR-17E Misc / Accessory
Amana TR-17LD Misc / Accessory
Amana TR-17LD-1 Misc / Accessory
Amana TR-17LE Misc / Accessory
Amana TR-19D Misc / Accessory
Amana TR-19E Misc / Accessory
Amana TR-19LD Misc / Accessory
Amana TR-19LE Misc / Accessory
Amana TR15-G Misc / Accessory
Amana TR15F-1 Misc / Accessory
Amana TR15F-1-A Misc / Accessory
Amana TR15F-1-AG Misc / Accessory
Amana TR15F-1-C Misc / Accessory
Amana TR15G Ref - Top Mount
Amana TR15G-A Ref - Top Mount
Amana TR15G-AG Ref - Top Mount
Amana TR15G-C Ref - Top Mount
Amana TR16B Ref - Top Mount
Amana TR16B-A Ref - Top Mount
Amana TR16B-C Ref - Top Mount
Amana TR16B-G Ref - Top Mount
Amana TR16B-L Ref - Top Mount
Amana TR16G Ref - Top Mount
Amana TR16H Ref - Top Mount
Amana TR16J Ref - Top Mount
Amana TR16J-A Ref - Top Mount
Amana TR16J-AG Misc / Accessory
Amana TR16J-C Misc / Accessory
Amana TR16K Ref - Top Mount
Amana TR16N Misc / Accessory
Amana TR16N-A Misc / Accessory
Amana TR16N-AG Misc / Accessory
Amana TR16N-C Misc / Accessory
Amana TR16W Misc / Accessory
Amana TR16W-A Misc / Accessory
  #2 (permalink)
Old 12-08-2008, 11:24 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
The filter you took out, what was the part#, should be on the filter.....GWF, MWF, or was it the culligan silver filter?
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 12-08-2008, 11:49 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
I may not be on when you get back, so here is your problem.....
Here is the plug you have---->Part Details - GE Water filter bypass plug, part number: WR02X10173
When you changed filters, at one point you had to get an adapter for the new filter (white) to fit in the filter head recepticle that is this part----->Part Details - GEH Ge smartwater™ refrigerator filter adapter, part number: ADAPTER
So, for you to use the bypass plug you have, you need to remove that adapter, it unscrews just like the filter does.
Hope this helps
__________________
  #4 (permalink)
Old 12-08-2008, 03:36 PM
Junior Member
Default Success in changing the filter
One of the keys was seeing a picture of the water filter adaptor and then I could see that it unscrewed using the larger disc portion, not just the center post. Thank-you so much.
The water comes out much faster now that it doesn't have to go through a plugged water filter.
Very grateful,
Happy Christmas and Merry New Year
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
