Discuss
Whirlpool Ice Maker not dispensing ice
 in
Refrigerator & Freezer Repair
I have a Whirlpool refrigerator that the ice dispensor quit working. There is no sound like a motor trying to
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool Ice Maker not dispensing ice
  #1 (permalink)
Old 12-08-2008, 03:31 AM
Junior Member
Charlie57 is on a distinguished road
Default Whirlpool Ice Maker not dispensing ice
Brand: Whirlpool   Age: 5 - 10 years
I have a Whirlpool refrigerator that the ice dispensor quit working. There is no sound like a motor trying to work, the piece that turns to dispense the ice is ok and will turn free, when removed from unit.
The unit makes and and dispenses water fine, everything else works fine.
Any Advice?
Charlie
Ads By Google
  #2 (permalink)
Old 12-08-2008, 04:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Charlie,
What is the complete model number of the refrigerator?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-08-2008, 07:08 PM
Junior Member
Default Model Number
Gene,
The Model is ED5FHEXLQ00
Manufacture Date 06-02
I appreciate any help!
Charlie
  #4 (permalink)
Old 12-09-2008, 01:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Charlie,
Did the ice gate in the door open when you push the ice lever?
Did you hear a click when you tried to get an ice cubes?
__________________
  #5 (permalink)
Old 12-09-2008, 03:14 PM
Junior Member
Default
Gene,
The door does open and there is no sound at all. Not even a click, it woud be no different unpluging the fridge and testing it.
Charlie
  #6 (permalink)
Old 12-10-2008, 09:07 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Charlie,
Remove the ice bin and the bracket (#1 on the break down diagram).
Remove the wires from the motor and check the motor for continuity.
Check for 120VAC to the motor while the dispenser calls for ice and the door light switch depressed.
Post the results.
__________________
  #7 (permalink)
Old 12-12-2008, 03:21 AM
Junior Member
Default
Gene,
Thank you for the information. I will do this on Sunday. I'll let you know what happens.
Thanks,
Charlie
  #8 (permalink)
Old 12-13-2008, 05:43 PM
Junior Member
Mark Minnick is on a distinguished road
Default Same problem
I am having a very similar problem with my Whirlpool icemaker - makes ice just fine but won't dispense crushed or cubed. When pressing the pad, it makes a noise that sounds like a low hum (has always made this noise) and then nothing follows.
Model # GF6NFFXTY00
Serial # SU1131453
  #9 (permalink)
Old 12-13-2008, 06:04 PM
Junior Member
Default
Mark,
I am going to try to trouble shoot mine Sunday. Are you sure the low hum is not the sound of the cold air you can here when you push the dispensor. Also our flap (that makes the seal) makes a funny noise as it closes.
Charlie
  #10 (permalink)
Old 12-14-2008, 05:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Mark,
The model number you posted does not come up. Verify and repost it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ice maker not dispensing ice connie5024 Refrigerator & Freezer Repair 0 01-08-2010 11:27 AM
Ice Maker water is dispensing into the bin instead of into the cube maker jghani Refrigerator & Freezer Repair 0 09-12-2009 10:27 AM
Ice Maker water is dispensing into the bin instead of into the cube maker jghani Refrigerator & Freezer Repair 0 09-12-2009 10:20 AM
ice maker not dispensing ice sgtjt1975 Refrigerator & Freezer Repair 1 01-09-2009 06:15 AM
Ice maker not dispensing ice LeeBrowne Refrigerator & Freezer Repair 0 02-12-2008 05:44 PM
