hi i read a post by gene about how to test the ice maker i tested for voltage at l&n it was good so i shorted t&h and the motor did not run in your post this means i need to order the module but i noticed if i push on the gear it will rotate thru the cycle and eject the ice and fill up again and make ice but go no further unless i press on the gear again so do you think it is the module thanks for any help mike
