Discuss
Compressor Start Relay failure
 in
Refrigerator & Freezer Repair
My Matag frig (model PSD265LGES) compressor sometimes fails to start. Had the 'clicking sound' from the compressor area, the compressor
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Compressor Start Relay failure
  #1 (permalink)
Old 01-29-2011, 01:04 PM
Junior Member
etechsteve is on a distinguished road
Default Compressor Start Relay failure
Brand: Maytag   Age: 5 - 10 years
to start. Had the 'clicking sound' from the compressor area, the compressor ohmed out fine. The PTC in the relay was shattered and the contacts were burned, so I replaced the Overload Relay (p/n WPL 67002527) and Capacitor (WPL 65889-4) and all was well for about a year --- now its happening once again, although the overload relay seems to be okay and I've replaced it twice.
The Start Cap checks out okay, replaced the relay once again and the frig cycles fine for a few days, but the compressor fails to start every few days.
((While waiting for the relay to be delivered, I was able to start the compressor every time with a breadboard rig where I discharge the cap thru a power resistor and then close a switch for a fraction-of-a-second to energize the start windings ))
What I don't understand is --- how can the compressor cycle fine for many days and then all of a sudden fail to star? When the compressor runs, the temp goes down fast and it seems to control the temp just fine.
It doesn't appear to be the relay ( I bought two this time ), or the start cap and the compressor windings seem okay...
Is there somthing else that can cause this (thermostat chattering, defrost problem) ?
Thanks in Advance for your help.
  #2 (permalink)
Old 01-30-2011, 05:07 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Your compressor now may be hard starting due to start winding damage. If you monitor the outlet voltage when it fails to start, you might find it is failing to start during peak usage times when the line voltage goes lower.If the compressor is very hot when it fails, you might have a condenser motor going bad, or just clogged condenser coils.
If you have a meter, you could check the compressor input voltage when it fails to start, might be a burn wire somewhere, although rather rare.
__________________
  #3 (permalink)
Old 01-30-2011, 07:52 AM
Junior Member
Default
THANKS for the info richappy --- the frig ran day and all night (but I'm sure it'll fail to start once more . I do have a couple of DVMs and will record the voltages next time. The condenser and evaproator coils and fans appear good ( this bout of trobble is especially annoying since I regularlly blow the dust from the coils and keep the frig real clean)
The compressor is never too hot to keey your hand on it, although at time of stall it is quite warm. It does seem that If the unit is turned off for about a half hour after a failure, then it will start okay.
I've recorded about 5+ ohms across the start windings and 4 across the run windings --- is that about right? any other compressor test I might do?
Any other tests that might uncover the problem ( got plenty of clip leads and meters, o'scope around. I actually enjoy this stuff (enjoy debugging a lot more when I'm sucessful ) I see that you're from the happy valley --- great place, I'm an alumi and seldom miss a home game
  #4 (permalink)
Old 01-30-2011, 08:05 AM
Senior Expert
APP Volunteer
Default
If the compressor stalls and overheats, you just might have either varnish buildup, or damaged windings. If so, probably new compressor time. The fact that it is intermittent might mean a burnt wire someplace.
Go to my article in the refrigerator section. Put in the search box "replacing compressor start devices"
In there, I mention using a GE PTC device that has 5 ohms cold. If less than yours, it just might reliably start your compressor, but it will not prevent compressor stall. Then add a 1000 joule surge protector to the wall outlet to prevent further damage.
Also, when you go to the next home game at Beaver stadium, stop by the Knights of Columbus concession stand # 7 directly in from gate B, I'm the manager there, just ask for Rich, will give you a free hot dog!
__________________
Last edited by richappy : 01-30-2011 at 08:29 AM. Reason: freebe hot dog, other stuff
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
compressor popping--new start relay/overload didn't help Taffin Refrigerator & Freezer Repair 5 03-29-2012 06:43 AM
compressor start relay is different from original one taherritt Refrigerator & Freezer Repair 0 01-29-2011 06:49 AM
dacor relay circ failure rmass Oven Repair (including Ranges and Cooktops) 0 10-22-2010 12:35 PM
Bad start relay = compressor starting to fail bluefitness Refrigerator & Freezer Repair 1 12-31-2009 05:20 PM
compressor start relay clicking mikrae Refrigerator & Freezer Repair 7 12-30-2009 07:40 AM
