Discuss
Everything Cleaned & Still Not Cold Enough
 in
Refrigerator & Freezer Repair
Two days ago I recieved a "cold" drink from my wife that tasted like room temp. I immediately stuck a
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Everything Cleaned & Still Not Cold Enough
  #1 (permalink)
Old 12-07-2008, 09:51 AM
Junior Member
Remy is on a distinguished road
Default Everything Cleaned & Still Not Cold Enough
Model Number: FRS20QRC   Brand: Frigidaire   Age: 5 - 10 years
Two days ago I recieved a "cold" drink from my wife that tasted like room temp. I immediately stuck a thermometer in the side by side fridge and freezer to find 32/60! I Googled my model and eventually found your great website. I queried my situation and found an EXCELLENT article or explanation by your appliance EXPERT from California. I found as he described a cooling coil caked with ice. After removing the rear panel I also found a FILTHY evaporative coil (we bought the refer used); I cleaned BOTH thoroughly. What I DID NOT find was the Defrost Unit as he described it. All I found was something with a few wires coming out of it that was connected to the fan, and I took EVERYTHING off of the inside back panel/duct. I also took a picture to "show" exactly what I found. I then checked the flow hole behind the crispers and it was wide open, as was the hole at the top which seems to be controlled by the refer's "Cooling Control" unit. I stuck my finger clear through the top hole from the freezer to the refer so I know it was wide open. With the refer clean INSIDE and OUT and dry as a bone and BOTH Temp Controls set at HALF WAY, I placed thermometers in both sides and went to bed. I awoke about 6 hours later to find the unit running quietly. I opened it to find 40Freezer/39Refer! I then turned the freezer to the 3/4 COLDEST position and an hour later it dropped the freezer temp to about 4 and the refer to 28. The last temperature readings certainly seem acceptable, but WHY was the freezer only at 40 and the refer at 39 after I turned it back on for 6 hours while I slept? Is something "going out" in the compressor? I would have assumed in 6 hours it would have back to normal temps? Thanks!
Ads By Google
Related Models
Frigidaire FRS20QRCD0 Frg(v3) / Refrigerator
Frigidaire FRS20QRCD1 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS20QRCD2 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS20QRCD3 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS20QRCD4 Frg(v1) / Refrigerator
Frigidaire FRS20QRCD5 Frg(v1) / Refrigerator
Frigidaire FRS20QRCD6 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS20QRCD7 Frg(v1) / Refrigerator
Frigidaire FRS20QRCD8 Frg(v1) / Refrigerator
Frigidaire FRS20QRCD9 Frg(v1) / Refrigerator
Frigidaire FRS20QRCW0 Frg(v4) / Refrigerator
Frigidaire FRS20QRCW1 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS20QRCW2 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS20QRCW3 Frg(v4) / Side By Side Refrigerator
Frigidaire FRS20QRCW4 Frg(v2) / Refrigerator
Frigidaire FRS20QRCW5 Frg(v2) / Refrigerator
Frigidaire FRS20QRCW6 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS20QRCW7 Frg(v2) / Refrigerator
Frigidaire FRS20QRCW8 Frg(v2) / Refrigerator
Frigidaire FRS20QRCW9 Frg(v2) / Refrigerator
Frigidaire FRS20WNFD0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS20WNFW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS20WRFD0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS20WRFW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS20WRHD1 Frg(v1) / Refrigerator
Frigidaire FRS20WRHD2 Frg(v1) / Freezer
Frigidaire FRS20WRHD3 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS20WRHD4 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS20WRHD5 Frg(v1) / Refrigerator
Frigidaire FRS20WRHD6 Frg(v1) / Refrigerator
Frigidaire FRS20WRHW1 Frg(v2) / Refrigerator
Frigidaire FRS20WRHW2 Frg(v2) / Freezer
Frigidaire FRS20WRHW3 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS20WRHW4 Frg(v4) / Side By Side Refrigerator
Frigidaire FRS20WRHW5 Frg(v2) / Refrigerator
Frigidaire FRS20WRHW6 Frg(v2) / Refrigerator
Frigidaire FRS20ZGFB0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS20ZGFD0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS20ZGFW0 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS20ZGGB0 Frg(v1)
Frigidaire FRS20ZGGB1 Frg(v2)
Frigidaire FRS20ZGGB2 Frg(v1) / Refrigerator
Frigidaire FRS20ZGGD0 Frg(v3)
Frigidaire FRS20ZGGD1 Frg(v4)
Frigidaire FRS20ZGGD2 Frg(v2) / Refrigerator
Frigidaire FRS20ZGGW0 Frg(v5)
Frigidaire FRS20ZGGW1 Frg(v6)
Frigidaire FRS20ZGGW2 Frg(v3) / Refrigerator
Frigidaire FRS20ZGJB0 Frg(v1) / Refrigerator
Frigidaire FRS20ZGJB1 Frg/refrigerator
Frigidaire FRS20ZGJB2
Frigidaire FRS20ZGJD0 Frg(v2) / Refrigerator
Frigidaire FRS20ZGJD1 Frg/refrigerator
Frigidaire FRS20ZGJD2
Frigidaire FRS20ZGJW0 Frg(v3) / Refrigerator
Frigidaire FRS20ZGJW1 Frg/refrigerator
Frigidaire FRS20ZGJW2
Frigidaire FRS20ZRGB1 Frg(v1) / Refrigerator
Frigidaire FRS20ZRGB2 Frg(v2) / Refrigerator
Frigidaire FRS20ZRGB3 Frg(v1) / Refrigerator
Frigidaire FRS20ZRGB4 Side By Side Refrigerator
Frigidaire FRS20ZRGB5 Side By Side Refrigerator
Frigidaire FRS20ZRGB6 Side By Side Refrigerator
Frigidaire FRS20ZRGB7 Frg(v1) / Refrigerator
Frigidaire FRS20ZRGB8 Frg(v1)
Frigidaire FRS20ZRGB9 Frg(v1) / Refrigerator
Frigidaire FRS20ZRGBA
Frigidaire FRS20ZRGD0 Frg(v1)
Frigidaire FRS20ZRGD1 Frg(v3) / Refrigerator
Frigidaire FRS20ZRGD2 Frg(v4) / Refrigerator
Frigidaire FRS20ZRGD3 Frg(v2) / Refrigerator
Frigidaire FRS20ZRGD4 Side By Side Refrigerator
Frigidaire FRS20ZRGD5 Side By Side Refrigerator
Frigidaire FRS20ZRGD6 Side By Side Refrigerator
Frigidaire FRS20ZRGD7 Frg(v2) / Refrigerator
Frigidaire FRS20ZRGD8 Frg(v2)
Frigidaire FRS20ZRGD9 Frg(v2) / Refrigerator
Frigidaire FRS20ZRGDA
Frigidaire FRS20ZRGW0 Frg(v2)
Frigidaire FRS20ZRGW1 Frg(v5) / Refrigerator
Frigidaire FRS20ZRGW2 Frg(v6) / Refrigerator
Frigidaire FRS20ZRGW3 Frg(v3) / Refrigerator
Frigidaire FRS20ZRGW4 Side By Side Refrigerator
Frigidaire FRS20ZRGW5 Side By Side Refrigerator
Frigidaire FRS20ZRGW6 Side By Side Refrigerator
Frigidaire FRS20ZRGW7 Frg(v3) / Refrigerator
Frigidaire FRS20ZRGW8 Frg(v3)
Frigidaire FRS20ZRGW9 Frg(v3) / Refrigerator
Frigidaire FRS20ZRGWA
Frigidaire FRS20ZSFB0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS20ZSFW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS20ZSGB0 Frg(v1)
Frigidaire FRS20ZSGB1 Frg(v2)
Frigidaire FRS20ZSGB2 Frg(v1) / Refrigerator
Frigidaire FRS20ZSGB3 Frg(v2) / Refrigerator
Frigidaire FRS20ZSHB0 Frg(v0) / Side By Side Refrigerator
Frigidaire FRS20ZSHB1 Frg(v0) / Side By Side Refrigerator
Frigidaire FRS20ZSHB2 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS20ZSHB3 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS20ZSHB4 Frigidaire/refrigerator
Frigidaire FRS20ZSHB5 Frigidaire/refrigerator
Frigidaire FRS22AGED2 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS22PRAD0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS22PRAD2 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS22PRAW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS22PRAW2 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS22PRBD0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS22PRBD1 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS22PRBW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS22PRBW1 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS22PRCD0 Frg(v3) / Side By Side Refrigerator
Frigidaire FRS22PRCD1 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS22PRCD3 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS22PRCW0 Frg(v4) / Side By Side Refrigerator
Frigidaire FRS22PRCW1 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS22PRCW3 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS22VSAD0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS22VSAW0 Frg(v2) / Side By Side Refrigerator
Frigidaire FRS22VSBD0 Frg(v1) / Side By Side Refrigerator
Frigidaire FRS22VSBD1 Frg(v1) / Refrigerator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cleaned Display now oven won't work whirlpoolmagic Oven Repair (including Ranges and Cooktops) 0 12-09-2009 08:23 AM
Whirlpool Duet - Cleaned Filter, now I have a leak PalmBayChuck Washer Repair 2 09-24-2009 05:26 PM
Right front burner won't light after it was cleaned lesn Oven Repair (including Ranges and Cooktops) 2 12-09-2008 06:23 AM
Dishes not cleaned Dreiding Dishwasher Repair 1 09-08-2008 07:56 PM
mico-wave door cleaned glennj Microwave Repair 1 08-10-2007 09:15 PM
