Replacement parts for WHIRLPOOL SS25HFXMS00 REFRIGERATOR | AppliancePartsPros.comHere is the tech sheet, see the attachment.
It tells you how to force a defrost cycle.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle, see the tech sheet till the fans and compressor turn off.
You do not have a mechanical timer you have an Adaptive Defrost Control board (Item 6 in Section 11)
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 33 in Section 9) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 35 in Section 9) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost board is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
