2 Pages12>
cmhaines
#1 Posted : Sunday, January 23, 2011 6:12:55 AM(UTC)
cmhaines
Refridgerator question: Kenmore model #596.52672200 Mfg#p52672000w0 Ser#10307373an
Problem: Refridgerator runs but does not cool freezer or fridge. Noticed prior to not cooling a fan noise by the compressor area. Checked all fans and they are all running.Checked condenser coils and they are clean. Checked panel behind compressor and can hear clicking noise at the compressor where switch relays are locataed. Thinking it could be a start relay or overload protector at the compressor by looking at fix it yourself manual but not sure of the name of the parts on this Kenmore model . Not sure how to test compressor parts. Pulled off one part that is approx 2x1 1/4(cmks shizuki nsk85212-44/75c) but not sure what this is. Any ideas? My email is hainescm@hotmail.com......Thanks.
#2 Posted : Monday, January 24, 2011 3:58:49 AM(UTC)
Here is the relay/overload for the compressor.
Part number: AP4013414
Click on the picture for more views/info.
Only applies if the compressor is clicking on/off fairly fast which by the sound of it is what is happening.
If the compressor is running then your problem is elsewhere. Usually you can hear it also feel it vibrating and it should be warm not hot.
Here are a couple sites that should help you troubleshoot. The second site has better info on how to check the parts.
http://www.applianceaid.com/frig.html
Appliance Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
cmhaines
#3 Posted : Monday, January 24, 2011 3:58:44 PM(UTC)
cmhaines
Thank you. I ordered the relay/overload part but have a question. How do I get the part off the compressor? I pulled on it but was afraid to pull to hard because I wasn't sure how it was connected.
Thanks again.
#4 Posted : Tuesday, January 25, 2011 6:08:13 AM(UTC)
Usually you have to remove a cover or a spring clip.
Here are a couple good site that should be useful.
cmhaines
#5 Posted : Tuesday, January 25, 2011 9:17:32 AM(UTC)
cmhaines
Thank you for replying. I did take the wire clip off and then pulled off a what looks like some kind relay that connects into the overload switch. The overload switch ( white peice from the picture) is attached to the compressor seems snug how is it attached to the compressor ? Is it held on by pins or two sided tape.I could take picture of it tonight and upload it. Thank you for your time.
#6 Posted : Wednesday, January 26, 2011 5:25:39 AM(UTC)
As far as I know it should just pull off.
cmhaines
#7 Posted : Wednesday, January 26, 2011 9:44:23 AM(UTC)
cmhaines
thank you. i'll let you know what happens,part should be here today.
cmhaines
#8 Posted : Thursday, January 27, 2011 3:29:20 PM(UTC)
cmhaines
just letting everyone know that the overload switch was the problem. frig running good. thank you for taking your time with this.
Chris
stuffy
#9 Posted : Tuesday, February 15, 2011 7:46:35 PM(UTC)
stuffy
I have a Kenmore bottom freezer refrigerator (Model #59679142990 MFG #P1321804TW) that does not cool, and just keeps blowing warm air, with a clicking noise in the back by the compressor every minute or so.
So I bought a start relay(#10097204) and a capacitor (#65889-4) from you about a month ago. I put the relay in and it worked perfect for about 3 weeks, ya! Then it started blowing warm air again (it continues to run) and clicking every so often as before.
After that I did put the capacitor in, but that didn’t change anything. And prior to all this, I replaced the defrost timer, with no change.
My limited knowledge of ohm testing:
-the compressor showed both the ‘start’ and ‘run’ had a reading of about .5x10, and the ground test showed no movement on the needle.
-the overload switch read ‘0’.
-have not found how to test the ‘solid state’ relay.
Some things that I have observed:
-both the fans are running
-the light switches are working
-the compressor is warm, not hot, and humming/vibrating
-the condenser coils have been cleaned
Could this problem be the ‘overload’? it did check out on the ohm meter. Your help would be much appreciated, I am out of ideas on what could be wrong with this frig!
Thanks!
#10 Posted : Wednesday, February 16, 2011 1:47:11 AM(UTC)
Pull the back freezer panel and check the frost pattern. If a little bit of frost at the input tubing, and no other frost, you either have a bad compressor, or it ran out of refrigerant due to a leak.
2 Pages12>
