Discuss
Freezer works fridge not cooling completely
 in
Refrigerator & Freezer Repair
Originally, refrigerator was 60-65 degrees, freezer fine. Completely defrosted unit, turned back on and it worked fine for about 5
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer works fridge not cooling completely
  #1 (permalink)
Old 01-22-2011, 01:31 PM
Junior Member
dankam is on a distinguished road
Default Freezer works fridge not cooling completely
Model Number: RB213TFW   Brand: Magic Chef   Age: More than 10 years
Originally, refrigerator was 60-65 degrees, freezer fine. Completely defrosted unit, turned back on and it worked fine for about 5 days.
Next, replaced the defrost timer, (I have confirmed the cycle starting around 7:00am and 7:00pm.) fridge worked fine for two weeks, now it is stuck at 50 degrees. There is nothing blocking the entry of cool air from the freezer, and from my inspection, the damper is not adjustable, I think it is always open. Is it possible the defrost heater is not working, and when the defrost cycle hits every 12 hours, just enough ice melts without the heater from the coils to allow the fridge to at least stay at 50 degrees.
Thanks for any help!
Ads By Google
Related Models
Magic Chef RB213TM Ref - Top Mount
Magic Chef RB213TV Ref - Top Mount
Magic Chef RB214AFM Ref - Top Mount
Magic Chef RB214AFV Ref - Top Mount
Magic Chef RB214AM Ref - Top Mount
Magic Chef RB214AV Ref - Top Mount
Magic Chef RB214PA Ref - Top Mount
Magic Chef RB214PV Ref - Top Mount
Magic Chef RB214RA Ref - Top Mount
Magic Chef RB214RFA Ref - Top Mount
Magic Chef RB214RFV Ref - Top Mount
Magic Chef RB214RV Ref - Top Mount
Magic Chef RB214TA Ref - Top Mount
Magic Chef RB214TFA Ref - Top Mount
Magic Chef RB214TFM Ref - Top Mount
Magic Chef RB214TFV Ref - Top Mount
Magic Chef RB214TM Ref - Top Mount
Magic Chef RB214TV Ref - Top Mount
Maytag RB2155BB Ref - Bottom Mounts
Maytag RB2155BB/XAA Ref - Bottom Mounts
Maytag RB2155SH Ref - Bottom Mounts
Maytag RB2155SH/XAA Ref - Bottom Mounts
Maytag RB2155SW Ref - Bottom Mounts
Maytag RB2155SW/XAA Ref - Bottom Mounts
Maytag RB215BSBB Ref - Bottom Mounts
Maytag RB215BSBB/XAA Ref - Bottom Mounts
Maytag RB215BSSB Ref - Bottom Mounts
Maytag RB215BSSB/XAA Ref - Bottom Mounts
Maytag RB215BSSW Ref - Bottom Mounts
Maytag RB215BSSW/XAA Ref - Bottom Mounts
Maytag RB215LABP Ref - Bottom Mounts
Maytag RB215LABP/XAA Ref - Bottom Mounts
Maytag RB215LASH Ref - Bottom Mounts
Maytag RB215LASH/XAA Ref - Bottom Mounts
Whirlpool RB21CKXAL00
Whirlpool RB21CKXAW00
Magic Chef RB21EA-3A Ref - Top Mount
Magic Chef RB21EN-3A Ref - Top Mount
Magic Chef RB21EY-3A Ref - Top Mount
Magic Chef RB21FA-3A Ref - Top Mount
Magic Chef RB21FN-3A Ref - Top Mount
Magic Chef RB21FY-3A Ref - Top Mount
Magic Chef RB21HA-3A Ref - Top Mount
Magic Chef RB21HN-3A Ref - Top Mount
Magic Chef RB21HY-3A Ref - Top Mount
Magic Chef RB21JA-4A Ref - Top Mount
Magic Chef RB21JN-4A Ref - Top Mount
Magic Chef RB21KA-2A Ref - Top Mount
Magic Chef RB21KA-4A Ref - Top Mount
Magic Chef RB21KA-4AT Ref - Top Mount
Magic Chef RB21KA4AF Ref - Top Mount
Magic Chef RB21KN-2A Ref - Top Mount
Magic Chef RB21KN-4A Ref - Top Mount
Magic Chef RB21KN-4AT Ref - Top Mount
Magic Chef RB21KN4AF Ref - Top Mount
  #2 (permalink)
Old 01-23-2011, 06:25 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Sounds like you still have a defrost problem.
Remove the evaporator cover from inside the freezer so you can see the coils.
If they are heavily iced/frosted over then you have a defrost problem.
it will show up first in the fresh food compartment and later in the freezer area.
Manually turn the defrost timer cam to force a defrost cycle.
Check that the heater is coming on.
Be careful that you do not burn your fingers.
If it does not come on unplug the unit and check the heater element, should be around 20 ohms.
If OK then check the defrost thermostat.
Should be 0 ohms when frozen.
Note it opens just above freezing and should be 240,000 when open.
If it looks bulged/deformed in any way replace it even if it measures OK.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
started up s/s fridge. freezer working fine, but fridge is not cooling dkusko Refrigerator & Freezer Repair 0 09-05-2010 09:40 AM
Freezer works fridge not cooling denimnlace Refrigerator & Freezer Repair 1 08-03-2010 01:45 PM
Replacing Fridge Fan, freezer works, fridge not cooling dlake1 Refrigerator & Freezer Repair 4 07-22-2010 06:01 AM
Freezer works poorly fridge inconsistent cooling billd0419 Refrigerator & Freezer Repair 1 07-19-2010 12:17 PM
GE fridge, Freezer works, fridge dont.. need repair manual kattkrzkatt Refrigerator & Freezer Repair 1 11-29-2008 09:45 AM
