Water leaking from door front
My water dispenser in the door leaks out the front onto the floor. I have changed the filter many times and it continues to leak. I believe it might be the valve that lets the water in. We have also tried to turn the water source down and overtime it will start leaking again. Sometimes my ice maker seems to get to much water and freezes all up. I am not sure if this is the same problem or if it is because of poor circulation. Does anyone have any suggestions. Thanks!
Leaky frigidaire frige in the front.
I found the issue to be the funnel whole above the drain tube in the back of the refrigerator is too big for the drain tube. When the condensation drips, half of the water misses the drain tube. The water that sits below the drain tube leaks down the outside of the tube. Design flaw. To keep the water from seaping below the flange of the drain tube, I used silicon caulking.
Hello.
To assist you we need the complete model number, please provide. Thank you. |
| All times are GMT -7. The time now is 09:45 AM. |
