| » GE refrig stops cooling and will not restart |
Model Number: TFX25JPCGWW Brand: GE Age: More than 10 years
Hello,
I have a GE refrig manufactured in 1999. It was in a house I just bought; so I have no history on his refrig. SYMPTOM: GE side by side refrig, when first plugged in, starts and cools quickly to the proper temps in the freezer and fresh food sections. BUT it stops cooling at some point and will not restart; (the freezer and fresh food sections are warm the next morning, but interior lights are working.) THINGS I HAVE OBSERVED AND TRIED TO GET THE REFRIG TO RESTART: 1) I slowly turned the defrost timer control clockwise 1 full turn. I hear a few "clicks" coming from the defrost timer while turning it, BUT the refrig does not restart. (Does this mean the defrost timer is MOST LIKELY NOT causing the no restart symptom?) QUESTION: When I turn the defrost timer control and hear the "clicks" I mentioned from the timer; SHOULD I WAIT A WHILE AFTER EACH "CLICK" TO GIVE THE REFRIG SOME TIME TO RESTART, OR SHOULD THE REFRIG RESTART IMMEDIATELY WHEN TURNING THE DEFROST TIMER CONTROL? 2) When I move the cold control from OFF to ON a few times the refrig restarts but still will stop cooling and not restart. 3) I wiggled the wiring harnesses to see if a possible loose connection might start or stop the refrig from cooling. Wiggling harnesss has NO EFFECT. 4) HERE IS THE INTERESTING PART: When I take the inside covers off the evaporator coil and evaporator fan ( and leave the covers off ). The refrig restarts and works properly. Possible bad defrost thermostat?? How would I test the defrost thermostat at the time refrig stops cooling? Anything else you think might be causing my no restart symptom? Any help would be greatly appreciated. Thanks, Gary Ads By Google Related Models Last edited by gary-b : 01-19-2011 at 02:51 PM. Reason: typo |
Quote:
Most likely the problem is a bad cold control. - The cold control Part number: AP3156221 Here are the breakdown diagrams and Replacement parts for General Electric TFX25JPCGWW Refrigerator | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Gary,
I do not see how it can be connected. Probably just a coincidence. Gene.
__________________
richappy,
Thanks for you advice. I will tap the cold control and short wires to confirm. I haven't removed the cold control yet; which wires get "shorted"? Are there only two wires on the cold control? Also, I can't find a wiring diagram on this refrig. Do you know where it might be? thanks, Gary |
Service data is either behind the control panel, or in back of the front kick panel. There are two wires to the control, just pull them off and short together to test fridg.
__________________
| Display Modes | |
| Refrigerator/Freezer stops cooling, then starts cooling, then stops cooling | angiebritt | Refrigerator & Freezer Repair | 3 | 07-22-2010 04:28 PM |
| dryer stops midcycle but will restart | sjc17blue | Dryer Repair | 0 | 06-16-2010 11:04 AM |
| Stops & won't Restart | dickward | Dryer Repair | 0 | 12-04-2009 10:24 AM |
| Dryer runs for 15 seconds, stops, & then won't restart | alohajbw | Dryer Repair | 1 | 03-18-2009 10:51 AM |
| Electric dryer Stops, then will restart | croberts | Dryer Repair | 3 | 01-04-2008 01:21 AM |
