Discuss
Whirlpool freezer and Refrig just started warming up
 in
Refrigerator & Freezer Repair
Our freezer and frig have just started warming up. The coils are clean ( as good as can be expected
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool freezer and Refrig just started warming up
  #1 (permalink)
Old 01-17-2011, 07:54 PM
Junior Member
stuartgto is on a distinguished road
Default Whirlpool freezer and Refrig just started warming up
Model Number: ET20DKXSW01   Brand: Whirlpool   Age: More than 10 years
Our freezer and frig have just started warming up. The coils are clean ( as good as can be expected with two dogs). The unit was purchased in 1988. Adjusting the controls does not seem to help. The freezer temp is about 32F and the fridge is about 54F. Any help is appreciated.
Ads By Google
Related Models
Whirlpool ET20DKXSW01
Whirlpool ET20DKXTF00
Whirlpool ET20DKXTF01
Whirlpool ET20DKXTF02
Whirlpool ET20DKXTF03
Whirlpool ET20DKXTF10
Whirlpool ET20DKXTG00
Whirlpool ET20DKXTG01
Whirlpool ET20DKXTG02
Whirlpool ET20DKXTG03
Whirlpool ET20DKXTG10
Whirlpool ET20DKXTM00
Whirlpool ET20DKXTM01
Whirlpool ET20DKXTM02
Whirlpool ET20DKXTM03
Whirlpool ET20DKXTM10
Whirlpool ET20DKXTN00
Whirlpool ET20DKXTN01
Whirlpool ET20DKXTN02
Whirlpool ET20DKXTN03
Whirlpool ET20DKXTN10
Whirlpool ET20DKXTW00
Whirlpool ET20DKXTW01
Whirlpool ET20DKXTW02
Whirlpool ET20DKXTW03
Whirlpool ET20DKXTW10
Whirlpool ET20DKXVF00
Whirlpool ET20DKXVF01
Whirlpool ET20DKXVF02
Whirlpool ET20DKXVF03
Whirlpool ET20DKXVF04
Whirlpool ET20DKXVF05
Whirlpool ET20DKXVF06
Whirlpool ET20DKXVF07
Whirlpool ET20DKXVG00
Whirlpool ET20DKXVG01
Whirlpool ET20DKXVG02
Whirlpool ET20DKXVG03
Whirlpool ET20DKXVG04
Whirlpool ET20DKXVG05
Whirlpool ET20DKXVG06
Whirlpool ET20DKXVG07
Whirlpool ET20DKXVM00
Whirlpool ET20DKXVM01
Whirlpool ET20DKXVM02
Whirlpool ET20DKXVM03
Whirlpool ET20DKXVM04
Whirlpool ET20DKXVM05
Whirlpool ET20DKXVM06
Whirlpool ET20DKXVM07
Whirlpool ET20DKXVN00
Whirlpool ET20DKXVN01
Whirlpool ET20DKXVN02
Whirlpool ET20DKXVN03
Whirlpool ET20DKXVN04
Whirlpool ET20DKXVN05
Whirlpool ET20DKXVN06
Whirlpool ET20DKXVN07
Whirlpool ET20DKXVW00
Whirlpool ET20DKXVW01
Whirlpool ET20DKXVW02
Whirlpool ET20DKXVW03
Whirlpool ET20DKXVW04
Whirlpool ET20DKXVW05
Whirlpool ET20DKXVW06
Whirlpool ET20DKXVW07
Whirlpool ET20DKXWG00
Whirlpool ET20DKXWG01
Whirlpool ET20DKXWG02
Whirlpool ET20DKXWG03
Whirlpool ET20DKXWN00
Whirlpool ET20DKXWN01
Whirlpool ET20DKXWN02
Whirlpool ET20DKXWN03
Whirlpool ET20DKXWW00
Whirlpool ET20DKXWW01
Whirlpool ET20DKXWW02
Whirlpool ET20DKXWW03
Whirlpool ET20DKXXN00
Whirlpool ET20DKXXN10
Whirlpool ET20DKXXN11
Whirlpool ET20DKXXW00
Whirlpool ET20DKXZN00
Whirlpool ET20DMXAB00
Whirlpool ET20DMXAB01
Whirlpool ET20DMXAN00
Whirlpool ET20DMXAN01
Whirlpool ET20DMXAW00
Whirlpool ET20DMXAW01
Whirlpool ET20DMXBB00
Whirlpool ET20DMXBN00
Whirlpool ET20DMXBW00
Whirlpool ET20EKXPWR0
Whirlpool ET20EKXPWR1
Whirlpool ET20EKXSW00
Whirlpool ET20F134KN0
Whirlpool ET20F134KN1
Whirlpool ET20F134KW0
Whirlpool ET20F134KW1
Whirlpool ET20GKXDN00
Whirlpool ET20GKXDN01
Whirlpool ET20GKXDN02
Whirlpool ET20GKXDN10
Whirlpool ET20GKXDW00
Whirlpool ET20GKXDW01
Whirlpool ET20GKXDW02
Whirlpool ET20GKXDW10
Whirlpool ET20GKXFN00
Whirlpool ET20GKXFN01
Whirlpool ET20GKXFW00
Whirlpool ET20GKXFW01
Whirlpool ET20GKXSW00
Whirlpool ET20GKXSW01
Whirlpool ET20GKXSW02
Whirlpool ET20GKXSW03
Whirlpool ET20GKXTF00
Whirlpool ET20GKXTF01
Whirlpool ET20GKXTG00
Whirlpool ET20GKXTG01
Whirlpool ET20GKXTM00
  #2 (permalink)
Old 01-18-2011, 05:44 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL ET20DKXSW01 | AppliancePartsPros.com
Is the compressor and the condenser/compressor fan running?
You can usually hear the compressor running. You should also be able to feel it vibrating and it should be warm.
Is the evaporator (freezer) fan running?
If the compressor and both fans are running, remove the evaporator cover from inside the freezer so you can check the coils.
If they are heavily iced up you probably have a defrost problem.
If yes do not defrost before finding out what is causing the problem.
If there is no frost or only frost in one area you probably have a sealed system problem.
__________________
  #3 (permalink)
Old 01-18-2011, 08:14 AM
Junior Member
Default
Both fans are running as is the compressor. After removing the back panel inside the freezer, the coils are heavily iced only on the top of the coils, from the ice maker side, halfway across the coils. /The icemaker was never installed. Now what can I do?
  #4 (permalink)
Old 01-18-2011, 01:38 PM
Senior Expert
APP Volunteer
Default
Sounds like you may have a sealed system problem.
Here is a good link.
http://www.applianceaid.com/refrigerator.html
Check out #20 and the example pictures part way down the page.
If it is a sealed system problem it will be a bad compressor, a blockage in the sealed system or low freon. All of them will be an expensive repair as you need a pro and there is no guarantee that the unit will be fixed.
It is usually best to put the dollars into a new unit.
If it is a defrost problem the evaporator coils have to be iced/frosted over to the point where the evaporator fan cannot pull air through the coils.
I would confirm whether is is a defrost or sealed system problem by doing a manual defrost.
Then put the evaporator cover etc. back in place and let it run for a couple hours. If you then only have frost in that one area it is a sealed system problem.
If there is frost evenly covering all the coils just get back to us and we will go through how to check the defrost system.
OR
Just search defrost problem in this forum.
__________________
  #5 (permalink)
Old 01-18-2011, 06:43 PM
Junior Member
Default
After defrosting the freezer coils and leting it run for 2 1/2 hours, the top of the freezer coils are startiing to freeze over and the temp in the freezer is 38deg. The tube right above the coils is also frozen over.
  #6 (permalink)
Old 01-19-2011, 02:45 AM
Senior Expert
APP Volunteer
Default
Unfortunately it sounds like a sealed system problem.
If the unit keeps running continuously but cannot get down to the correct temperatures then I would replace the unit.
Note: It may shut down for half an hour or so but this will just be it going through a defrost cycle (all fans and compressor will be off)
If it was a defrost problem the unit would get down to the set point temperatures and then start cycling and running correctly until the ice/frost build up became heavy enough to cause problems usually a week or so.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge warming but Freezer OK GlennH Refrigerator & Freezer Repair 1 08-15-2010 03:33 PM
Whirlpool refrig/freezer freezer cold refig not resha Refrigerator & Freezer Repair 1 12-07-2009 08:38 PM
Whirlpool refrig/freezer freezer cold refig not resha Refrigerator & Freezer Repair 0 12-05-2009 08:50 AM
Refrig and freezer stopped working, then started...then stopped again Auvan0876 Refrigerator & Freezer Repair 2 08-28-2009 07:29 PM
Fridge & Freezer warming Paula D Refrigerator & Freezer Repair 0 09-04-2008 07:08 PM
