Ice maker does not fill with water. Tube is clear, solinode opens and closes, infrered sensor tests OK. I assume this leaves only the control board (part #2252183). Is there anything else I should try?
Originally Posted by: Gary1950E Ice maker does not fill with water. Tube is clear, solinode opens and closes, infrered sensor tests OK. I assume this leaves only the control board (part #2252183). Is there anything else I should try? Gary, No, don't replace that control board. That control has nothing to do with the icemaker production. Based on your post, The control you need is the emitter board kit, It could "test" Ok, and still not send the voltage up to the icemaker control head. Part number: AP3137510
That's your most likely problem. Good Luck, :) :) :)
