Discuss
Water Dispenser Dripping
 in
Refrigerator & Freezer Repair
The water dispenser on the freezer door of my Kenmore Coldspot Fridge will sometimes drip after use. This makes for
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water Dispenser Dripping
  #1 (permalink)
Old 10-11-2007, 06:54 PM
Carr Boy Carr Boy is offline
Junior Member
Carr Boy is on a distinguished road
Default Water Dispenser Dripping
Model Number: 1069555720   Brand: Kenmore   Age: 5 - 10 years
will sometimes drip after use. This makes for quite a mess if it drips overnight!
Need repair suggestions. Details please. I'm a novice. Thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-12-2007, 05:16 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Probably a bad water solenoid in the back of fridg. Also, could be low water pressure to it. When replacing it, check the water pressure by loosing the line to it and verify "decent" pressure. Your solenoid is available by clicking on your model # above.
__________________
  #3 (permalink)
Old 10-13-2007, 05:33 AM
Junior Member
Default
Could the problem have anything to do with where the water is dispensed? The pressure is good and a glass is filled quickly. I was wondering if an adjustment could be made around the dispensing arm b/f I start replacing parts. Also, I'm unable to find my Model # from the list I have to choose from. If I still need to replace the part, should I use one from another Model?
Thanks.
  #4 (permalink)
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
- Replacement solenoid valve for your Sears model (might look slightly different from the old valve). This is a dual solenoid valve - one solenoid supplies water to the ice maker and another to the water dispenser - this is the solenoid richappy is talking about (only available as a complete valve).
  #5 (permalink)
Old 10-13-2007, 05:36 AM
Administrator
APP Team
Default
We don't have your model in our index, but we do carry all parts for it.
- Here is a diagram showing the icemaker, valve and water line
Let me know if you need info on any other part or contact our customer service dept.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water/ice dispenser schumske Refrigerator & Freezer Repair 2 10-10-2007 04:26 PM
water dispenser dripping/needs cleaning lniederk Refrigerator & Freezer Repair 0 10-03-2007 10:19 AM
ice dispenser working...water dispenser not rishuk Refrigerator & Freezer Repair 0 09-25-2007 04:03 PM
water leak from Ice dispenser tsherman Refrigerator & Freezer Repair 0 09-02-2007 02:31 PM
whirpool frige water dripping from dispenser chaspitifer Refrigerator & Freezer Repair 1 08-09-2007 05:53 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
