| » Kenmore Side By Side Door Seals Very Hot |
Model Number: 51552101 Brand: Kenmore Age: 5 - 10 years
My Kenmore side by side's door seals are very hot to the touch. Along with the wall between the freezer and refrigerator. What is causing this?
Quote:
If you move the fridge away from the wall, Remove the vented panel at the bottom of the back wall, You'll most likely find, that the condenser fan motor is barely turning, if at all. Or the condenser coil is blocked with debris, or even both are a possibility. I would have been happy to supply apossible part number for the fan, but the model number you supplied is incorrect. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
I think you mis understood the blog, Without the model number I'm not sure, In most side by side fridges, the condenser heat tube, yoder loop or post condenser loop, is routed down the front mullion strip(panel between the compartments). The condenser & loop system serves two purposes: To transfer/dissipate the heat from the sealed system,into the room. the heat from the yoder loop system, is used to transfer heat to the mullion strip, to eliminate moisture and condensation from the strip between the compartments. If the condenser coil is blocked with debris, or the fan doesn't run properly, it does not transfer properly. The first place you, the consumer, will notice it, is the mullion strip or gaskets. I'm sure you'll be fine once you clean the coils, and get a fan motor that runs properly.
__________________
I checked the Model # and it was correct. ?. Anyway I pulled the frig out and took off the bottom panel. The fan was turning fine. The coils were completely blocked. I blew off all the coils with a air hose. It was packed in there like cotton. Now I am waiting to see if it takes care of the problem. Here is the Mod # again 51552101 mfg date 2001-06 serial # SL2235337
Quote:
C3dan, Great, Glad the fan motor's OK. Remember, it's going to be really warm(low 100's dgrs), but not HOT, and you'll find, if you clean that condenser coil and the area under and around the refrigerator at least once a year, your fridge will be more efficient, and last you a long time. Good Luck,
__________________
Quote:
Did you see the previous post ? The mullion strip will be warm/hot, it does transfer the warmth to the seals,keeps them soft and sealing proper. I don't think you have a problem, I'm honestly surprrised, you didn't mention any food spoilage, or temperature problems on the inside of the unit, based on how clogged up you made it sound.
__________________
Temp control seems to be fine. Milk is good and cold. Ice cubes are fine. Only thing I ever noticed was the seal being warm. i check it a few times a day, and sometimes I will it notice the seals cooler. Thanks again for your help.
Quote:
C3dan, Sounds great, we're pretty sure you'll be OK, from here on out. Good Luck,
__________________
| Display Modes | |
| Kenmore side by side model clicks and buzzes every 60-120 seconds and stopped cooling | 67rustang | Refrigerator & Freezer Repair | 2 | 05-03-2012 09:02 AM |
| Kenmore side-by-side too cold in fresh food side. | scorp508 | Refrigerator & Freezer Repair | 9 | 01-09-2011 12:48 PM |
| Kenmore Side by Side 363 7512413 Freezer and Refrigerator won't freeze and cool. | SandraKUnkel | Refrigerator & Freezer Repair | 0 | 07-24-2010 09:15 AM |
| Kenmore Side-by-Side - Drain pan overflow after fixing ice door chute. Coincidence? | jeaton | Refrigerator & Freezer Repair | 10 | 07-07-2009 02:49 PM |
| Kenmore Side By Side - Door Water Dispenser Leaks | FIXITMOM | Refrigerator & Freezer Repair | 0 | 09-24-2008 07:03 AM |
