ice maker not making ice, but water still coming out of the door
Originally Posted by: nette41 ice maker not making ice, but water still coming out of the door Nette, A couple of things to check, Are you sure the icemaker is turned on ? check the switch on the side of the front assembly. Check and make sure the left door light switch is oprating properly. The technical data sheet should be located behind the kickplate grille in a plastic bag in the front of the unit. You will be able to perform several tests, to all components of the refrigerator, so we can get a better idea of what may be wrong. :) :) :)
