Ice/Water dispenser not working, when leaver pushed to dispense ice or water light dims and fan motor slows, after a few seconds cooling fan goes back to standard speed.
Now while checking questions on this subject here on the board it seems the main control board located at the bottom rear is the problem.
But here's a twist, cooling fan has been oscillating up and down in frequency/speed over time, upon removing the control board in freezer door that controls ice/water the fan stops oscillating and has been a steady frequency/speed since. Is the main control board discussed affecting the ice/water board or is it the ice/water control board itself?
Broker Dave
Without a response to my question guess I'll take a shot in the dark and order the ice/water control board as the fridge is working fine without the board in place.
Also the wife is ready to disown me cause coffee taste different with tap water and spending the money will be worth it to drink my Java in peace.
Hey Broker, did you ever resolve the problem with your Ice & Water dispenser? I have been living with this for quite sometime too but, I'm torn between ordering the main control board or just the dispenser control board.
