Discuss
Could it be the thermosat?
 in
Refrigerator & Freezer Repair
I have what seems to be a short in the freezer of my side by side. My question is could
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Could it be the thermosat?
  #1 (permalink)
Old 10-10-2007, 05:57 PM
don419 don419 is offline
Junior Member
don419 is on a distinguished road
Smile Could it be the thermosat?
Model Number: frs24wsgw1   Brand: Frigidaire   Age: 5 - 10 years
I have what seems to be a short in the freezer of my side by side. My question is could the thermostat be my problem? I turned the defrost control on the lower bottom of the frig. And put the unit in defrost the heater came on and defrosted the condenser coil. Then I turned the defrost control again to get out of the defrost cycle and the breaker blew. At this point you can't reset breaker but if I continue with turning the control the ref. comes out of this cycle and you can reset breaker and everything works fine.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-10-2007, 08:35 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You probably have a shorted compressor.
__________________
  #3 (permalink)
Old 10-10-2007, 08:46 PM
Junior Member
Default
Is that something major or is it a matter of finding a short?
and you don't think the short is in the thermostat
  #4 (permalink)
Old 10-10-2007, 08:48 PM
Junior Member
Default
  #5 (permalink)
Old 10-11-2007, 02:58 AM
Senior Expert
APP Volunteer
Default
Do you mean that NOW the compressor works fine!!!
__________________
  #6 (permalink)
Old 10-11-2007, 12:10 PM
Junior Member
Default
the compressor works fine after you turn the defrost timer out of defrost mode! And reset breaker.
  #7 (permalink)
Old 10-11-2007, 05:36 PM
Senior Expert
APP Volunteer
Default
Switches don't short, wires and connectors do. You might just have a shorting wire in the freezer or near the defrost control, look for panel burn marks.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
