The MFG number for the refrigerator is: P131530W W While attempting to replace our water filter I broke the plastic tube with an "o ring" on the bottom of the assembly where filter attaches. :mad: In searching your parts lists for the water filter assembly I don't see anything with the small plastic tube I broke. What part do I need? Thanks for your help. David Sprouse
