Moved refrigerator from kitchen to basement and now it's not cooling. when you open the door the light comes on so it has power. I tried turning the controls up but it did not help.
A model number may help other help you.
I am assuming that the compressor does not come on.
If the compressor, the condenser fan and the evaporator fan are all off you may be in a defrost cycle which is usually half an hour long. Wait to see if it will come out of defrost.
If the fans work but the compressor does not check that you have not knocked a wire off going to the compressor or the start device on the compressor has come loose. |
THIS FORUM IS DEAD!!!!!!! |
