Will not dispense crushed or cubed ice, tested motor and solenoid for auger and ice crusher, both are ok. Water dispenser operates as it is suppose to. I do not have any schematics for control wiring, but looking at a break down of the parts for the dispenser, there is a micro switch in the assembly. I am not sure if it is for the ice or water dispensing mechanism the should close as the lever that calls for the ice is pushed. I would appreciate any info before I begin attempting to remove the front cover of the door unit
