Our frig set on medium cool, discovered everything is solid frozen????:(
Hard to say without a model number.
Check the temperature in the freezer. It should be 0 to 5 degrees F. If it is way lower the thermostat needs replacing.
If just the fresh food side is too cold it could be the damper control. |
THIS FORUM IS DEAD!!!!!!! |
