| » Samsung RS2630 Frost free freeze has ice build up at the bottom of freezer |
Model Number: RS2630SH Brand: Samsung Age: 5 - 10 years
hi
I have a Samsung RS2630SH fridge with a frost free freezer. Just yesterday we noticed icy build up at the bottom of the freezer. We cleared the ice and also cleared the block vents in the freezer. The issue is that the ice has come back. Any clue as to what to look at. The door seal looks good and the vents are now clear in the freezer. Also, just before we noticed this issue the fridge made a lot of noises. But it has since stopped once the vents were cleared. Thanks Ads By Google Related Models |
I shut off the fridge and let it defrost. I opened up the freezer compartment back panel and notice the drain completed iced up. The evaporator coils had no ice sheets and were not iced up at all. The defrost heater seemed to work fine as I do see it come on in the freezer. There is an orange glow.
My question is with the drain plug. How does it get so iced up. The water in there seems to be iced up as well. Correct me if i am wrong but isn't there heater coils to evaporate the water. Could that be the issue. If so how do get access to replace it if i had and could you please help me with a part number and name etc. I do plan on letting it thaw our and restarting the fridge to see if the issue comes back. Thanks |
Hey, just saw your post. I am having the same problem with icing, and drain seems to be clogged below the coils in the back also. Did you ever find a solution for yourself? I think maybe mine is the icemaker also, because I noticed a trail of ice that seemed to stem from the top. Any assistance or advice you may have is welcome. Thanks!
hi jdeakins3,
No solution yet, however I am pretty confident that somehow the issue is with the icemaker. I suspect that the icemaker is somehow leaking water that is collecting on the drain pan causing it to freeze up. As it seems that my clogged drain issue has stopped once I switched the icemaker off. I have not had the time to troubleshoot the issue with the icemaker but will update you with what i find. In the mean time if anyone else has had this issue please chime in. Thanks |
| Display Modes | |
| frost free refrigerator/freezer frosting over on back wall or bottom freezer | bwheeler | Refrigerator & Freezer Repair | 2 | 01-31-2011 07:16 AM |
| frost free freeze up | dscott7 | Refrigerator & Freezer Repair | 3 | 02-05-2010 01:29 PM |
| frost free freezer ice build up again | mherskind | Refrigerator & Freezer Repair | 2 | 05-05-2009 03:05 AM |
| Frost Build-Up in freezer (refrig & freezer not as Cold as usual) | boots1 | Oven Repair (including Ranges and Cooktops) | 1 | 01-18-2009 03:08 AM |
| Freezer cold, evaporator fan not working, frost build up in freezer | heretolearn2 | Refrigerator & Freezer Repair | 3 | 05-28-2008 02:45 PM |
