Neither side of my side by side are getting cold. System running. I have replaced capacitor and starter relay. I have ohmd out my defrost heaters and they are fine I have advanced my defrost timer till it turns off. and then rotated till it comes on. Any help would be appreciated. Thanks:confused:
Here are your parts Replacement parts for General Electric TFX20RRAWH Refrigerator | AppliancePartsPros.comBy "System running" I am assuming that the compressor is running. Remove the cover in the freezer so you can see the coils. Note: The unit has to be running for several hours without a defrost cycle. If the coils are clogged with frost/ice, it is probably a defrost problem. But by the sound of it you are getting very little if any cooling so I doubt this is your problem. If the coils have no frost or just frost in one area then you have a sealed system problem. This will be an expensive repair with no guarantee that it will fix the unit long term. Often it makes more sense to invest the dollars into a new unit. |
THIS FORUM IS DEAD!!!!!!! |
