Discuss
Kenmore Dryer Electrical Issue
 in
Refrigerator & Freezer Repair
I have an electric front load Kenmore dryer model 4178405200, serial number XD52505812 that is 5 years old. Clothes are
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Dryer Electrical Issue
  #1 (permalink)
Old 01-03-2011, 10:34 AM
Junior Member
rhemshot is on a distinguished road
Exclamation Kenmore Dryer Electrical Issue
Model Number: 4178405200   Brand: Kenmore   Age: 1 - 5 years
I have an electric front load Kenmore dryer model 4178405200, serial number XD52505812 that is 5 years old. Clothes are not drying completely and the lights on the front panel above the Pause/Cancel (Drying, Cool Down Wrinkle Rid, and Clean Lint Filter) and Start button will flash and beep 9 times. I would dry a load and pull the machine away from the wall and look through a small hole on the back panel to see that the heating element is working.
I noticed by touching the electrical plug-in portion and slightly moving it clock or counter clock wise the dryer would cause it to stop. I turned off the breaker and unscrewed the 4 screws to the electrical socket to see if the four wires were loose and it is not loose. After putting the screws in the wall mount electrical plate I dried a new load and the machine performed correctly. I then dried a new load and moved the electrical plug-in and the dryer stopped. Could a wire be touching another or is the black socket bad. The wires going into the socket have their plastic coating on them except for the ground wire that is tightly screwed into the bracket. After the dryer stopped I just pressed the start button again and the dryer is heating as normal. Would you recommend replacing the electrical socket or something else?
Ads By Google
Related Models
Kenmore 41784052500 DRYER
Kenmore 41784072300 DRYER
Kenmore 41784082500 DRYER
Kenmore 41784092500 DRYER
Kenmore 41784130000 DRYER
Kenmore 41784131000 DRYER
Kenmore 41784132000 DRYER
Kenmore 41784152500 DRYER
Kenmore 41784252500 DRYER
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41787042700 DRYER
Kenmore 41788042700 DRYER
Kenmore 41788052700 DRYER
Kenmore 41788056700 DRYER
Kenmore 41788076700 DRYER
Kenmore 41788988100 ELECTRIC DRYER
Kenmore 41788988800 ELECTRIC DRYER
Kenmore 41788989100 GAS DRYER
Kenmore 41788989800 GAS DRYER
Kenmore 41789090100 WASHER DRYER COMBINATION
Kenmore 41789090110 COMBINATION WASHER-DRYER
Kenmore 41789090200 WASHER DRYER COMBINATION
Kenmore 41789090210 COMBINATION WASHER-DRYER
Kenmore 41789090400 WASHER DRYER COMBINATION
Kenmore 41789090410 COMBINATION WASHER-DRYER
Kenmore 41789090600 WASHER DRYER COMBINATION
Kenmore 41789090610 COMBINATION WASHER-DRYER
Kenmore 41789090800 WASHER DRYER COMBINATION
Kenmore 41789090810 COMBINATION WASHER-DRYER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
Kenmore 41789190800 COMBINATION WASHER/DRYER
Kenmore 41789190810 COMBINATION WASHER/DRYER
Kenmore 41789190820 COMBINATION WASHER/DRYER
Kenmore 41789195100 COMBINATION WASHER/DRYER
Kenmore 41789195110 COMBINATION WASHER/DRYER
Kenmore 41789195120 COMBINATION WASHER/DRYER
Kenmore 41789195600 COMBINATION WASHER/DRYER
Kenmore 41789195610 COMBINATION WASHER/DRYER
Kenmore 41789195620 COMBINATION WASHER/DRYER
Kenmore 41789195800 COMBINATION WASHER/DRYER
Kenmore 41789195810 COMBINATION WASHER/DRYER
Kenmore 41789195820 COMBINATION WASHER/DRYER
Kenmore 41789390100 COMBINATION WASHER/DRYER
Kenmore 41789390101 COMB, WASHER/DRYER
Kenmore 41789390110 COMBINATION WASHER/DRYER
Kenmore 41789390600 COMBINATION WASHER/DRYER
Kenmore 41789390700 COMBINATION WASHER/DRYER
Kenmore 41789390701 COMB, WASHER/DRYER
Kenmore 41789390710 COMBINATION WASHER/DRYER
Kenmore 41789390800 COMBINATION WASHER/DRYER
Kenmore 41789390801 COMB, WASHER/DRYER
Kenmore 41789390810 COMBINATION WASHER/DRYER
Kenmore 41789395100 WASHER-DRYER
Kenmore 41789395101 COMBINATION WASHER/DRYER
Kenmore 41789395110 COMBINATION WASHER/DRYER
Kenmore 41789395600 WASHER-DRYER
Kenmore 41789395701 COMBINATION WASHER/DRYER
Kenmore 41789395710 COMBINATION WASHER/DRYER
Kenmore 41789395800 WASHER-DRYER
Kenmore 41789395801 COMBINATION WASHER/DRYER
Kenmore 41789395810 COMBINATION WASHER/DRYER
Kenmore 4178965120 WASHER/DRYER
Kenmore 4178965720 WASHER/DRYER
Kenmore 4178965820 WASHER/DRYER
Kenmore 41789690100 COMBINATION WASHER/DRYER
Kenmore 41789690110 COMBINATION WASHER/DRYER
Kenmore 41789690120 WASHER/DRYER
Kenmore 41789690130 COMBINATION WASHER/DRYER
Kenmore 41789690700 COMBINATION WASHER/DRYER
Kenmore 41789690710 COMBINATION WASHER/DRYER
Kenmore 41789690720 WASHER/DRYER
Kenmore 41789690730 COMBINATION WASHER/DRYER
Kenmore 41789690800 COMBINATION WASHER/DRYER
Kenmore 41789690810 COMBINATION WASHER/DRYER
Kenmore 41789690820 WASHER/DRYER
Kenmore 41789690830 COMBINATION WASHER/DRYER
Kenmore 41789695100 COMBINATION WASHER/DRYER
Kenmore 41789695110 COMBINATION WASHER/DRYER
Kenmore 41789695120 WASHER/DRYER
Kenmore 41789695130 COMBINATION WASHER/DRYER
Kenmore 41789695700 COMBINATION WASHER/DRYER
Kenmore 41789695710 COMBINATION WASHER/DRYER
Kenmore 41789695720 WASHER/DRYER
Kenmore 41789695730 COMBINATION WASHER/DRYER
Kenmore 41789695800 COMBINATION WASHER/DRYER
Kenmore 41789695810 COMBINATION WASHER/DRYER
Kenmore 41789695820 WASHER/DRYER
Kenmore 41789695830 COMBINATION WASHER/DRYER
Kenmore 41789870100 Laundry Centers
Kenmore 41789870110 WASHER/DRYER
Kenmore 41789870700 Laundry Centers
Kenmore 41789870710 WASHER/DRYER
Kenmore 41789870800 Laundry Centers
Kenmore 41789870810 Laundry Centers
Kenmore 41789875100 Laundry Centers
Kenmore 41789875110 Laundry Centers
Kenmore 41789875700 Laundry Centers
Kenmore 41789875710 WASHER/DRYER
Kenmore 41789875800 Laundry Centers
Kenmore 41789875810 Laundry Centers
Kenmore 41789970100 Laundry Centers
Kenmore 41789970800 Laundry Centers
Kenmore 41789975100 Laundry Centers
Kenmore 41789975800 Laundry Centers
Kenmore 41789980100 WASHER/DRYER
Kenmore 41789980800 WASHER/DRYER
Kenmore 41790032990 DRYER
Kenmore 41790042990 DRYER
Kenmore 41790042991 DRYER
Kenmore 41790052990 DRYER
Kenmore 41790052991 DRYER
Kenmore 41790142000 DRYER
Kenmore 41790412700 DRYER
Kenmore 41790412701 DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electrical stove top issue stubbs836 Oven Repair (including Ranges and Cooktops) 0 10-16-2010 07:42 PM
Kenmore gas dryer ignitor issue mjmalone Dryer Repair 0 09-04-2010 06:24 PM
Electrical Issue? byoungmadison Refrigerator & Freezer Repair 3 05-13-2010 03:23 PM
electrical issue? jillserdo Oven Repair (including Ranges and Cooktops) 0 10-03-2009 07:32 AM
Kenmore Dryer Issue kjmelvin3 Dryer Repair 20 05-08-2008 07:50 PM
