Hello, The fridge has just started to cool less than what is appropriate and food is quickly spoiling as a result. 1. I have turned dial to coldest temp. 2. Fan is blowing cool air into the fridge.
Compressor was changed about 2 years ago. Is it necessarily the same problem?
A model number may help others help you.
[COLOR="Blue"]Compressor was changed about 2 years ago. Is it necessarily the same problem?[/COLOR] No, it can be a number of things. You could have a defrost problem you will still get cool air but it will not be cold enough to keep the fresh food section cold enough. Usually a defrost problem will show up in the fresh food first and then in the freezer side. Usually the compressor will run continuously or more often with a defrost problem.
Could be the damper between the sections i not opening fully.
Could be a thermostat problem. |
THIS FORUM IS DEAD!!!!!!! |
Model number is PLRU1777DS. Fridge and freezer are seperate units.
