| » ICE Maker Not making ICE |
Model Number: KSCS25INSS00 Brand: Kitchen Aid Age: 1 - 5 years
The ice maker stopped making ice. Water in door works fine. Trouble shooting found a voltage problem (i believe) I removed the ice makes unit and unplugged the power cord (White, black, cream, green) 4 wire cable.
I measured the voltage at the connector in the freezer and between the white (N) and the Black (L) wires I only have 106 volts. Why? If I power the unit from a different source it all works fine. I guessing here that my problem is power coming into the ice maker not the actual ice maker its self. Where does this cable come from? thanks Jim Ads By Google Related Models |
Quote:
Jim, You most likely have a bad "Reciever Board" on the automated ice dispenser system. The easiest way to test the board / ice maker is: *** Remove power to the refrigerator *** This will be a live voltage test,so be careful... Remove the reciever board assembly( the control on the right side of the freezer wall), Disconnect the wire harness from the printed circuit board. With a jumper wire(paper clip seems to work best), install the jumper wire between pin 3 and pin 4 on the wire harness connector, (usually black with a white stripe and black with a yellow stripe). Restore power to the refrigerator and check for 120 VAC at the black and white wires at the ice maker wall harness. If 120 VAC is present, order and replace the control board kit, Part number: AP3137510 If you still have the wrong voltage, you'll need to check the harness, for loose connections or frayed wiring. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Joe thank you for your reply. Just hoping you typo'ed the pins I do not have a pin 4 but I did a quick ohm check and jumpeded pin 3 to pin 5 and that gave me 120 volts to the ice maker. So guessing I have a cap leaking on that board which is causing the low voltage.
Thank you for your help. jim |
Quote:
Jim, I'm still sure you're needing the board kit, But, I don't have a wiring diagram simillar to yours, there may have been an engineering change, but, again I'm sure the new kit will solve your problem. Make sure you install the complete(both boards) kit.
__________________
| Display Modes | |
| Ice maker not making ice | tmoceri | Refrigerator & Freezer Repair | 4 | 08-12-2010 02:57 PM |
| Ice maker not making ice | Shawn Boast | Refrigerator & Freezer Repair | 0 | 05-31-2010 10:58 PM |
| Ice maker not making ice | kschimpf | Refrigerator & Freezer Repair | 3 | 04-04-2009 02:19 PM |
| Ice Maker Not Making Ice | Dklemm | Refrigerator & Freezer Repair | 0 | 07-09-2008 08:14 PM |
| ice maker not making ice | perescusa | Refrigerator & Freezer Repair | 0 | 12-29-2007 03:02 PM |
