Ice despenser stopped working--blow dryed motor--connected 110 vts. motor good---did same to sel. 110 vts. good. was going to check door switch for Ice despenser cannot get plastic that covers switches ( outside of door) off. could you please tell me how to get the plastic off without breaking it . Can get putty knife in there or small screw driver in there. but afraid it will snap under pressure. Help Please!!!! I also read on your site that the plastic that holds the switch may be broken. Please advise how to get the switch open so I can get the parts ordered from you asap.Thank You Much Barry
