My water dispensor quit working. I suspected the water filter, so I put a new one on. Still no water. I played around with the water dispenser lever and it ocassionally dispensed a good stream of water. (mostly none) I suspect dirty contacts on the lever/switch. I can't play around with the lever for 5 min. ea. time I want water. Is it possible to clean some contacts or will I have to get a new control unit?
Also, How do I get into the working mech. Do I pry off the front pannel?
GS
