Discuss
Kenmore Side by Side - Fridge Not Cooling
 in
Refrigerator & Freezer Repair
Hi folks - Could use some advice with my Kenmore Side by Side Mode 106.56579400 Had a repair tech come
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Side by Side - Fridge Not Cooling
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-09-2007, 02:58 PM
pharmaman pharmaman is offline
Junior Member
pharmaman is on a distinguished road
Default Kenmore Side by Side - Fridge Not Cooling
Model Number: 106.56579400   Brand: Kenmore   Age: 1 - 5 years
Hi folks -
Mode 106.56579400
Had a repair tech come to my place to look at the unit - fridge wasn't cooling and I had ice in the back of the freezer. I am thinking defrost cycle not working.
Tech says I need a control board and a new bi-metal thermostat. Comes to do repair a few days later and replaces the board. When I ask about the thermostat the tech says that the thermostat is on the board. Is this right?
Little hairs standing up on the back of my neck. On the repair invoice it calls out for both the thermostat and control board. Did I just get ripped off or was it just a typo on the invoice?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-10-2007, 02:27 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I searched the sears site at sears3.com and found control board. Give us a part # of the board he replaced. Also, there is NO thermostat on any control board I have ever seen. This Sears site shows p# 2252199 sells for $204
__________________
  #3 (permalink)
Old 10-11-2007, 02:01 PM
doityourselfer doityourselfer is offline
Junior Member
doityourselfer is on a distinguished road
Default
I had a similar problem and was also told it was the control board. I ordered a control board from these folks ($156) and installed but still had the same problem. I don't blame you for being a little apprehensive about obtaining a control board. I wish I would have been. Anyhow, richappy (on this forum) suggested I try running diagnostics. Would that be applicable to this situation? Good luck. I'll keep watching your post.
  #4 (permalink)
Old 10-11-2007, 04:45 PM
Senior Expert
APP Volunteer
Default
He probably replaced the termination thermostat in the freezer and the control board just to make sure he didn't have a call back. Board probably ok.
Did he do a manual defrost test. If not, he may have replaced a board that is ok.
For your info, one way to activate auto defrost is to turn cold control off 15 seconds, then on 5, then off 15, then on 5, then off. Within 3 seconds adaptive defrost will enter defrost mode, you will hear the relay click. If not, go to Appliance repairs, Appliancehelp, Appliances, repairs to dryers washers dishwashers fridges repairs microwaves ge maytag kenmore frigidaire westinghouse inglis, appliance how to take apart information, purchasing an appliance help, model number help, for alternate defrost initiate info.
For Whirlpool products I usually assume one failure, if termination thermostat was bad, I would have just replaced it and nothing else. Ie, termination thermostats don't blow out adaptive defrost boards and adaptive defrost boards don't blow out termination thermostats!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridgidaire Gallery series Side-by-Side built 08/95 Boomer1970 General Talk 3 10-08-2007 02:21 PM
Kenmore side-by-side fridge water dispenser Marvster Refrigerator & Freezer Repair 0 09-25-2007 12:34 PM
Kenmore Side by Side Going through defrost mode at top ref. and freezer briant97 Refrigerator & Freezer Repair 1 09-18-2007 06:16 AM
Amana Side by Side Refrigerator Freezer MFG. P1317202WE josephbowles@earthlink.ne Refrigerator & Freezer Repair 0 08-10-2007 05:38 PM
Refer side not cooling properly, freezer okay lynbo11 Refrigerator & Freezer Repair 0 07-30-2007 07:02 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
