Discuss
Frigidaire air damper - loud buzzing, replaced motor no change
 in
Refrigerator & Freezer Repair
I have a Frigidiare side by side, only about 22 months old, all electronic controls. Came home one day to
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Frigidaire air damper - loud buzzing, replaced motor no change
  #1 (permalink)
Old 11-26-2008, 06:47 AM
Junior Member
Flot is on a distinguished road
Default Frigidaire air damper - loud buzzing, replaced motor no change
Brand: Frigidaire   Age: 1 - 5 years
Came home one day to hear a loud buzzing/ratcheting noise from the fridge. Got the parts diagram and determined it was the damper control servo motor making the noise.
So I ordered a new damper assembly. Annoyingly the one I got didn't have quite the same setup with respect to switches or door design, but the motor was the same. Swapped in the new servo motor and the new one is doing exactly the same thing.
Ideas?? The damper appears to have two settings, there are two rocker switches that I guess provide feedback to the control board as to whether the door is half open, full open, or closed.
Not sure where to look next. Control board? The switches themselves?? Motor still "works" but when it is in the open or half open state it makes this constant loud buzz which is driving me nuts!!!
Ads By Google
  #2 (permalink)
Old 11-26-2008, 09:06 AM
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
well nowyou know the problem isn't the motor........ got a model number?
__________________
  #3 (permalink)
Old 11-26-2008, 04:17 PM
Junior Member
Default
..which strikes me as bizarre, since it's a 120vac motor with 2 wires running to it. I can't imagine what could be going on to send the motor into the buzzing fits that it goes through.
The model of the fridge is PLHS68EESB6
  #4 (permalink)
Old 11-26-2008, 06:06 PM
Senior Expert
APP Volunteer
Default
kinda pointing towards the board don't ya think? There should be a mini manual check in the grill area orcontrol panel or they used to tape them to the bottom of the case behind the grill
__________________
  #5 (permalink)
Old 11-26-2008, 07:11 PM
Senior Expert
APP Volunteer
Default
ftp://ftp.electrolux-na.com/ProdInfo.../241636602.pdf
__________________
  #6 (permalink)
Old 11-30-2008, 06:35 AM
Junior Member
Default
Hmm, ok I'm still at a loss, the circuit looks pretty simple... but what's controlling the power to the 2 toggle switches? Would it be possible that it's one of the toggle switches with the problem? That seems unlikely as the "pulsing/buzzing" is so consistant...
  #7 (permalink)
Old 12-08-2008, 03:51 PM
Junior Member
Default
Well, the good news is, the motor hasn't burned out. Bad news is, still making the horrible noise... any suggestions for other was to diagnose? Nothing else seems to be misbehaving..
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire fan and air damper pulsing? dsudduth Refrigerator & Freezer Repair 3 10-09-2009 10:37 AM
Replaced damper, still wont close mooch Refrigerator & Freezer Repair 0 09-01-2009 06:48 AM
how to change a damper homayounz Refrigerator & Freezer Repair 0 08-31-2009 03:24 PM
Replaced Damper, Refer Still Freezing Food Dswinty Refrigerator & Freezer Repair 0 02-16-2009 06:35 PM
Frigidaire Damper replacement danen1973 Refrigerator & Freezer Repair 0 01-30-2009 10:46 AM
