for me it happens every 3 or 4 mo. first the freezer gets ice along the bottom then it seems to work its way up to the drain tube. after enough ice surrounds the fan i know that its time to defrost it. i repaired appliances for a living back in the day. and normally i would run a copper wire from the defrost heater down the drain tube...however i don't see a defrost heater.
