Discuss
Freezer only cooling to 20 degrees F
 in
Refrigerator & Freezer Repair
I am troubleshhoting a 9 year old Kenmore refrigerator (model 596.79279993) with the freezer on the bottom. The freezer will
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer only cooling to 20 degrees F
  #1 (permalink)
Old 11-24-2008, 08:35 AM
Junior Member
Ron B is on a distinguished road
Cool Freezer only cooling to 20 degrees F
Model Number: 596.79279993   Brand: Kenmore   Age: 5 - 10 years
I am troubleshhoting a 9 year old Kenmore refrigerator (model 596.79279993) with the freezer on the bottom. The freezer will not get below plus 20 degrees F, even when thermostat in both the fridge and freezer are set to maximum cold (7 on the dial). The condenser coils are totally clean, conderser fan is running, evaporator coils are clean (no ice) and the evap fan is running, air flows into fridge from freezer like it is suppose, lights in fridge and freezer shut off when doors are closed (like they should), compressor runs continuously, sounds normal, slight hum can be felt when placing your hand on it. Compressor surface is about 10 degrees above ambient, condenser coils feel like they are at ambient temperature. Auodefrost timer rotates over time, it shuts off the compressor and runs the defrost heater as it should.
I think the uit is either low on refrigerant (takes 4.5 ounces of 134a) or the compressor is going bad. Am I on the right track? I see on your web site a compressor kit Part Number: AP3179962
Manufacturer's Number: 8201558 (10927206) made by WHIRLPOOL. Does this kit come with installation instructions? How do I know what the high and low side pressures should be when properly charged with the right amount of refrigerant?
Related Models
Kenmore 59650002100 REFRIGERATOR
Kenmore 59650003100 REFRIGERATOR
Kenmore 59650004100 REFRIGERATOR
Kenmore 59650009100 REFRIGERATOR
Kenmore 59650012100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59650013100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59650014100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59650019100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59650392000 REFRIGERATOR
Kenmore 59650392001 REFRIGERATOR SXS
Kenmore 59650392990 SIDE-BY-SIDE
Kenmore 59650394000 REFRIGERATOR
Kenmore 59650394001 REFRIGERATOR SXS
Kenmore 59650394990 SIDE-BY-SIDE
Kenmore 59650399000 REFRIGERATOR
Kenmore 59650399001 REFRIGERATOR SXS
Kenmore 59650399990 SIDE-BY-SIDE
Kenmore 59650692000 KENMORE SXS REFRIGERATOR
Kenmore 59650692001 REFRIGERATOR SXS
Kenmore 59650694000 KENMORE SXS REFRIGERATOR
Kenmore 59650694001 REFRIGERATOR SXS
Kenmore 59650699000 KENMORE SXS REFRIGERATOR
Kenmore 59650699001 REFRIGERATOR SXS
Kenmore 59651672100 26 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59651673100 26 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59651674100 26 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59651679100 26 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59652672200 KENMORE REFRIGERATION
Kenmore 59652672201 KENMORE REFRIGERATOR
Kenmore 59652672202 KENMORE REFRIGERATION
Kenmore 59652673200 KENMORE REFRIGERATION
Kenmore 59652673201 KENMORE REFRIGERATOR
Kenmore 59652673202 KENMORE REFRIGERATION
Kenmore 59652674200 KENMORE REFRIGERATION
Kenmore 59652674201 KENMORE REFRIGERATOR
Kenmore 59652674202 KENMORE REFRIGERATION
Kenmore 59652679200 KENMORE REFRIGERATION
Kenmore 59652679201 KENMORE REFRIGERATOR
Kenmore 59652679202 KENMORE REFRIGERATION
Kenmore 59653462300 KENMORE REFRIGERATOR
Kenmore 59653462301 KENMORE REFRIGERATOR
Kenmore 59653462302 KENMORE REFRIGERATOR
Kenmore 59653463300 KENMORE REFRIGERATOR
Kenmore 59653463301 KENMORE REFRIGERATOR
Kenmore 59653463302 KENMORE REFRIGERATOR
Kenmore 59653464300 KENMORE REFRIGERATOR
Kenmore 59653464301 KENMORE REFRIGERATOR
Kenmore 59653464302 KENMORE REFRIGERATOR
Kenmore 59653469300 KENMORE REFRIGERATOR
Kenmore 59653469301 KENMORE REFRIGERATOR
Kenmore 59653469302 KENMORE REFRIGERATOR
Kenmore 59655652500 KENMORE REFRIGERATOR
Kenmore 59655653500 KENMORE REFRIGERATOR
Kenmore 59655654500 KENMORE REFRIGERATOR
Kenmore 59655659500 KENMORE REFRIGERATOR
Kenmore 59655662500 KENMORE REFRIGERATOR
Kenmore 59655663500 KENMORE REFRIGERATOR
Kenmore 59655664500 KENMORE REFRIGERATOR
Kenmore 59655669500 KENMORE REFRIGERATOR
Kenmore 59657002600 KENMORE REFRIGERATOR
Kenmore 59657003600 KENMORE REFRIGERATOR
Kenmore 59657006600 KENMORE REFRIGERATOR
Kenmore 59657009600 KENMORE REFRIGERATOR
Kenmore 59657012600 KENMORE REFRIGERATOR
Kenmore 59657013600 KENMORE REFRIGERATOR
Kenmore 59657016600 KENMORE REFRIGERATOR
Kenmore 59657019600 KENMORE REFRIGERATOR
Kenmore 59657043600 KENMORE REFRIGERATOR
Kenmore 59657049600 KENMORE REFRIGERATOR
Kenmore 59657053600 KENMORE REFRIGERATOR
Kenmore 59657059600 KENMORE REFRIGERATOR
Kenmore 59657082790 20" BUILDERS SIDE BY SIDE
Kenmore 59657082791 20 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657085790 20" BUILDERS SIDE BY SIDE
Kenmore 59657085791 20 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657087790 20 BUILDERS SIDE BY SIDE
Kenmore 59657087791 20 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657089790 20" BUILDERS SIDE BY SIDE
Kenmore 59657089791 20 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657542790 25 SIDE BY SIDE REFRIGERATOR
Kenmore 59657542791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657547790 25 SIDE BY SIDE REFRIGERATOR
Kenmore 59657547791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657582790 25 SIDE BY SIDE REFRIGERATOR
Kenmore 59657582791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657585790 25 SIDE BY SIDE REFRIGERATOR
Kenmore 59657585791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59657587790 SIDE BY SIDE REFRIGERATOR
Kenmore 59657587791 25 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658392890 Side-by-Side
Kenmore 59658395890 Side-by-Side
Kenmore 59658397890 Side-by-Side
Kenmore 59658622990 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658627990 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658632890 Side-by-Side
Kenmore 59658632891 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658634000 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658635890 Side-by-Side
Kenmore 59658635891 SIDE-BY-SIDE REFRIGERATOR
Kenmore 59658637890 Side-by-Side
Kenmore 59658642890 Side-by-Side
Kenmore 59658642891 REFRIGERATOR
Kenmore 59658644000 REFRIGERATOR
Kenmore 59658647890 Side-by-Side
Kenmore 59658692890 Side-by-Side
Kenmore 59658695890 Side-by-Side
Kenmore 59658697890 Side-by-Side
Kenmore 59661102100 REFRIGERATOR
Kenmore 59661102101 REFRIGERATOR
Kenmore 59661103100 REFRIGERATOR
Kenmore 59661103101 REFRIGERATOR
Kenmore 59661104100 REFRIGERATOR
Kenmore 59661104101 REFRIGERATOR
Kenmore 59661109100 REFRIGERATOR
Kenmore 59661109101 REFRIGERATOR
Kenmore 59661142100 REFRIGERATOR
Kenmore 59661142101 REFRIGERATOR
Kenmore 59661144100 REFRIGERATOR
Kenmore 59661144101 REFRIGERATOR
Kenmore 59661152100 REFRIGERATOR
  #2 (permalink)
Old 11-24-2008, 10:14 AM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
It sounds like a freon leak, which will require a EPA certified technician for repair.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 11-24-2008, 10:19 AM
Junior Member
Default
Thanks for the thoughts. Woudl you attempt to have someone find the leak or send this unit to the landifll and spend $2000 to buy a new one?
  #4 (permalink)
Old 11-24-2008, 10:22 AM
Senior Expert
APP Volunteer
Default
I would have a tech check it out and if it is a sealed system problem it's still cheaper to repair than replace.
Nat
__________________
  #5 (permalink)
Old 11-25-2008, 02:40 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
If the tech. can find a minor leak with flourescent die, it's worth fixing. If a bad compressor plus leaky evaporator, a $600 repair cost would be more than the fridg. is worth.
There is still a probability it may fail again from some other problem; so for many customers, it's not worth it.
__________________
  #6 (permalink)
Old 11-25-2008, 03:59 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is a site with indicators of low freon
http://www.applianceaid.com/frig_notcold.html
Check out the Example pictures at the bottom of the main text.
Try checking the coils after the unit has been running for 2 or 3 hours without a defrost.
__________________
  #7 (permalink)
Old 10-06-2017, 06:16 AM
Junior Member
WileyOne1 is on a distinguished road
Default I am having the same issue
I have a 10-year-old bottom freezer that is set to 6 degrees. Recently it has started to temp alarm. The front panel display agrees with my laser temp sensor: 20 degrees.
I also notice significant frost beginning to build up in the freezer compartment.
The refrigerator is running fine.
What is the most likely cause?
  #8 (permalink)
Old 10-06-2017, 06:45 AM
Senior Expert
APP Volunteer
Default
Could be a defrost problem if the frost is at the back re: evaporator.
First remove the evaporator cover in the freezer so you can see the coils.
If they are heavily iced/frosted over then it is a defrost problem.
Do not let them de-ice.
If yes.
Manually force a defrost cycle by turning the defrost timer cam.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer/defrost control board needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item in Section ) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item in Section ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If it is on the food and walls then it could be a door seal problem.
Check your door seals
Make sure they are clean
Get a 2 inch wide piece of paper and place it between the seal and frame.
Then pull it out to check the seal
Work your way around both doors every 8 inches or so.
__________________
  #9 (permalink)
Old 10-10-2017, 08:41 AM
Junior Member
Default followup
Thank you for the detailed procedure.
I haven't had 2 minutes to pull any covers yet, but I have been monitoring the compartment temperatures. Today the freezer is between 10 and 15 depending where I point my laser, even though it is set to 6. There is still frost all over the food. I will do the door seal test this weekend.
But, I wanted to ask ...
When the temps begin to rise, I hear some clicking, maybe once or twice per second like a relay is trying to close. Does this suggest anything?
If yes.
If not on.
Unplug the unit.
If the heater is OK
  #10 (permalink)
Old 10-10-2017, 11:10 AM
Junior Member
Default followup
If yes.
If not on.
Unplug the unit.
If the heater is OK
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer/Upright Outside use to -10 Degrees Pacman Refrigerator & Freezer Repair 1 11-08-2009 07:54 AM
freezer ok... fridge bottom 3o...top 45 degrees r damico Refrigerator & Freezer Repair 0 07-14-2009 05:46 AM
Fridge is 70 degrees, freezer zero HELP JohnnyRoosMom Refrigerator & Freezer Repair 1 06-15-2009 12:13 PM
Freezer only gets to 27 degrees xxxx Refrigerator & Freezer Repair 0 05-02-2009 07:14 AM
Freezer and Fridge too cold, below 0 degrees! jsweeney Refrigerator & Freezer Repair 1 12-21-2008 03:15 PM
