| » Kenmore side-by-side too cold in fresh food side. |
Model Number: 106.55382400 Brand: Kenmore Age: 1 - 5 years
Hi Everyone,
Our Kenmore side-by-side (106.55382400) is too cold in the fresh food area. The digital controls suggest a setting of 4 (Goes 1-7 with 1 being lowest) for both the freezer and fresh food sections. With the fresh food section set to 1 we're still seeing about 30-32* (F) on the top shelf, and anything you put into the lowest drawer freezes. I've cleaned the front of the condensor that you can actually reach. There doesn't appear to be any adjustable louvers in the top or middle of the center wall. I don't notice it running any longer than usual, but to be honest I'm not in the kitchen enough each day to really be able to say what would be unusual. I've seen other threads suggest the cold control may have failed, but wanted to see if there are any other possible suggestions. Ironically the owners manual has troubleshooting steps for everything except "Refrigerator is too cold". Thank you greatly in advance. Ads By Google Related Models Last edited by scorp508 : 12-23-2010 at 09:31 PM. |
You will need to go to the Sears site, ********************************, to get the parts breakdown info. In the fridg liner picture look at the diffuser part #15 Check to see if the damper door is jammed open in this. If ok, check the fridg section thermistor, item12, part # 2188819
__________________
- Last edited by richappy : 12-24-2010 at 02:14 AM. |
I finally got around to yanking the thermistor from the fresh food side out.
Sitting in my living room @ 66* I'm getting a reading of ~3,650 ohms. If I submerge it in water as close to 77* as I can get it, I read ~1,980 ohms. At 71* as the water cooled it was ~2,240 ohms. I've ordered a couple thermistors and other parts I had been putting off. I have the diffuser out as well. It did appear as if the slats were in the open position even with the unit turned off. They're open right now as it sits in my hand and I can't forcibly close them. Does the unit use something like a worm gear which makes it impossible by hand, or should this be relatively easy? Last edited by scorp508 : 01-09-2011 at 11:46 AM. Reason: Added more info. |
Disassembled the motor and saw the white cog that moves the slats open and shut. I plugged it in with the parts visible and when you turn on the refrigerator the cog spins 180* then come to a stop. This appears to be the "open" position to let air in from the freezer side. I have it all back together and just have the diffuser sitting on the top shelf to see what happens when it cools down.
I found that the Power + Filter Reset for 3 seconds also works on this model to get into diagnostics mode. Interestingly both thermistors say they pass, and the diffusor door test does cycle the baffle open and shut properly during its test.
I'll still replace the thermistors and see what happens. |
| Display Modes | |
| side by side refrigerator - fridge side freezing food, water coming out of freezer | bomb | Refrigerator & Freezer Repair | 8 | 08-30-2011 01:58 PM |
| Freezer cold fresh food side warm | TOPGLOCK | Refrigerator & Freezer Repair | 1 | 05-26-2010 08:29 PM |
| Sears Kenmore side by side runs 24/7 freezer cold but not freezing | patrickmcglashan | Refrigerator & Freezer Repair | 0 | 02-08-2010 12:18 PM |
| GE side by side refrig tfh22prsm ww leaking from bottom, no longer cold either side | thomashaskins | Refrigerator & Freezer Repair | 3 | 09-13-2009 07:01 PM |
| freezer is cold fresh food side is warm | dprather | Refrigerator & Freezer Repair | 2 | 05-08-2009 03:37 AM |
