Billaban
#1 Posted : Monday, December 20, 2010 8:31:59 AM(UTC)
Billaban
Greetings,
The digital control console on this unit appears to be dead. None of the temp up/down control buttons or the assorted on/off buttons for alarms and etc are working.
Refridgerator temp is set/"stuck"? at 40F. Actually temp is around 35F. Freezer is set/"stuck" at -5F. Not sure what actual temp is but it is maintaining ice.
Suspect that this is a dead control board. Looks like an easy replace task. Looking for confirmation, i.e., is this a no-brainer or could the culprit be something else.
Thanks.
#2 Posted : Monday, December 20, 2010 11:13:03 AM(UTC)
Looks like you are on the right track and the new control board should fix the problem.
- The control board Part number: AP4366538
