Hello to all forum people I am new here and am posting my first Q. I have replaced the defrost heater in my freezer from a single element to a double. Followed the instructions and read some posts here too. After replacing the heater and then letting it run for a day with the panel still removed I noticed that there was ice building up on the coils mostly on the upper portion. Is that normal? Also is there a set time that the fridge needed to be off for anything to reset? oops the model number is suppose to be GSS22JEPCWW
thanks in advance
Put the freezer panel back and check your freezer and fridg temperatures after a few days and post.
I did as you requested and all seems to be working just fine, thanks
you can close this post as resolved
