You have been a member since:: 12/18/2010(UTC) Posts: 4
Hi, I have a Whirlpool side-by-side refrigerator, model # ED5FHGXNQ00 with an icemaker. The icemaker stopped making ice a couple days ago. I did some research on it and started diagnosing the motor module to see what the problem might be. I used a jumper wire to the holes marked T and H and nothing happens, in terms of going through its cycle. I then used the jumper wire to the holes marked V and L and water did start entering the icemaker. Temp. inside the freezer is fine and the feeler arm is connected into the back of the head of the icemaker as it should be. Since there isn't a problem with getting water to the unit it seems then that the problem would be with the motor module. Any other thoughts or other testing I could do to confirm this better?
Thanks, Olmbre
