srod407
#1 Posted : Wednesday, November 19, 2008 6:29:25 PM(UTC)
srod407
have and ice maker that dont want to get water.wont do anything,did you think is the valve,ice maker,or mother board
srod407
#2 Posted : Wednesday, November 19, 2008 6:36:46 PM(UTC)
srod407
neeed help on my ice maker,wont make ice,not getting water
libertyappl
#3 Posted : Wednesday, November 19, 2008 7:55:46 PM(UTC)
libertyappl
Try switching the leads on the water valve and pressing the water dispenser then look to see if it put water in the icemaker.
Here's your parts breakdown Model GC1SHAXMB00
Nat
KINGKONG
#4 Posted : Thursday, November 20, 2008 9:44:53 AM(UTC)
KINGKONG
Seems to be a very common prob w this icemaker! .....could be a faulty bimetal sensor [#27 in the parts guide], freezer temp above 17 degrees, frozen fill tube, or blocked/faulty ice level sensor [red light].
csears40
#5 Posted : Saturday, November 29, 2008 2:06:46 PM(UTC)
csears40
Nat
where could i get a part brakedown of model #25358687895
libertyappl
#6 Posted : Sunday, November 30, 2008 5:53:25 AM(UTC)
libertyappl
csears40,
you can go to searspartsdirect and type in your model number.
Nat
kayakcrzy
#7 Posted : Sunday, November 30, 2008 7:49:26 AM(UTC)
kayakcrzy
LOL!!! This looks light guessing 101. LOL!!! The first thing you need to do is look at the fingers that knock the ice out. They should be at 3 o'clock. The fingers should be just above the horizon of the icemaker. If not replace the icemaker. If they are, lets run a cycle. Take the cover off the ice maker, and you will see holes with letters next to them. Get a piece of wire, about 8 inches long, and strip back the ends, about a half inch, and stick 1 end in the M hole, and the other in the N hole, and the motor should start turning. If not replace the motor module. If it does turn, count to about 15, and then pull the jumper wire out of the holes. If the icemaker completes the cycle, and no water comes in, you either have a bad water valve. That is the part that the water line connects to. Or you might want to check the water tube that drops the water into the icemaker to be sure it is not frozen. Let me know what you find. Tom ApplianceEducator.com
Whirpool ice maker dripping water into ice (Refrigerator & Freezer Repair)
by biddergirl 3/9/2017 7:40:44 AM(UTC)
Whirpool Ice Maker Corroding Black debris in ice (Refrigerator & Freezer Repair)
by tomkarl 11/19/2012 1:39:26 PM(UTC)
Whirpool Ice Maker not cycling water (Refrigerator & Freezer Repair)
by gator1996 3/2/2012 4:45:11 PM(UTC)
Whirpool ice maker not getting water (Refrigerator & Freezer Repair)
by bjustice 5/6/2009 9:13:54 AM(UTC)
whirpool ice maker (Refrigerator & Freezer Repair)
by jstan 3/26/2009 6:19:53 AM(UTC)
