I turn on the ice maker and it works fine for about 5 days - fills the entire bucket with ice. Then ice builds up around the fan inside the cold compartment until the ice hits the fan blades. At this point, everything freezes uo and the tray doesn't dump ice. If I turn it off and let it defrost and warm up, the same cycle will be repeated. can a low refrigerant charge cause this problem? What else can I check?:)
